You should be fine doing what you listed above. Go for it.![]()
Read tons of posts. Here is what I planning on doing.
1. Clean with dishsoap/water
2. Wipe with waxoff
3. Use duplicorol primer. There is nothing special for plastic in Autozone, should I look for better one? I'm planning on doing few coats so I can sand and remove imperfections
4. sand primer ligthly and paint. I'm planning on using interior paint by duplicolor. But does it matter if it's interior paint? I'm painting over primer anyway...
Do I need adhesion promoter or ABS will be fine? Do I need special primer?
Thanks!
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
No need for special interior primer? Just pick one from those they have?
No need to do adhesion promoter on sanded ABS if I clean it very well?
Honestly, just read the can. If it says you can use it on ABS (plastic) you'll be just fine. This goes for the primer and the paint.
I've never used adhesion promoted and never had any issues. As you said, just be sure to clean it good between sanding/priming/sanding/painting and you'll be fine.
CarPC:
Sound System:
i always use the rustoleum plastic primer, never had anything EVER peel with that, including some flexible HDPE plastic i painted.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
I've had good luck with krylon fusion, it's supposed to bond to the plastic itself, and I've had no issues to date. Right on the can it says "No Sanding, No Primer Needed" so you should be fine with that. (Wal Mart carries it, and I think Home Depot and Lowes do as well)
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
problem with the fusion stuff is you are stuck to whatever colors they offer, which if i remember correctly dont really correspond to many interiors. i used the rustoleum plastic primer and covered it with the spray can form of plasti dip, and its a near match to my factory plastics in both color and texture.
krylon might make a fusion primer, allowing you to choose a top coat that best matches your interior, but i am not sure.
Pictures
I used the fusion as a primer, and then got a different can to match the color I was after. Fusion will bond to ABS, and the other paint will bond to the fusion...
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
