Let's see -- if you put it where the HVAC controls are, you have to move the controls (which can be dicey, depending on whether they're electronic, or mechanical, or vacuum), and the screen will partially block the vents.
If you put it down below, in the little switch panel location, it will partially block the Alpine screen.
What if you lowered the Alpine screen, and put the new unit in above it? Then it would block the HVAC controls a little, but probably not enough that they'd be unusable. You'd want to watch how far out the screen is when installed, to be sure it would clear the controls; that would determine how far into the dash you could install it.
LinkBack URL
About LinkBacks
