Results 1 to 10 of 13
Thread: windows and CF keep locking up :s
    Apr 2008
    originally i had my hdd mounted vertically in my trunk and everytime i went over a slight bump the music with start to skip and the computer locks up. i then moutned it horizontally and for about a day or so it was perfect and i even went over man holes on purpose to test it, untill today when i went over another bump it locked up. my system is a p4 3.0ghz, 2gb dd2 ram, 360gb IDE hdd, m4-atx 250W. any help please! the rest of the system works awesome! except for this i really need to get it fixed before any perminent damage to the hdd.
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    more info needed:
    Where and how do you have it mounted?
    Pics maybe?
    more specs on HDD (manufacturer, speed, etc...)
    Do you use the whole 360GB? depending on what is up with the hard drive, it might be worth getting a new laptop drive, but it might be a simple fix.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Apr 2008
    its a 2006 honda civic the entire computer is mounted in the spare tire well. the hdd is screwd down right to the car. i'm at work right now so i can't take any pics the hdd is a maxtor 7200rpm and so far i have only used about 100gb
    Feb 2006
    Melbourne, Australia
    Sounds like you have a bad connection somewhere, firstly check all you power-cables, both to the computer, and then internal too, make sure data cables are seated properly.
    Br,
    MrBean
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    May 2007
    Lakehood, CO
    I was thinking something along those lines.
    It's pretty rare to have a fairly new hard drive fail like that. It seems more like there's a bad connection somewhere. If it is the drive, then I would try to sell that one on ebay, and buy a new one...
    Also, horizontal or vertical shouldn't matter too much. Search the forum for Hard Drive Mounting or something like that. It's a debate that is as old as this forum and the general consensus is that it doesn't matter how it's mounted as long as it is secure.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by mrbean_phillip View Post
    Quote Originally Posted by monkeyracer View Post
    . . . It seems more like there's a bad connection somewhere.
    I agree on the connection issue, and I'd suggest a much softer mounting, too. It sounds like this is a 3.5-inch drive, intended for static use, and you're using it as a mobile. The 2.5-inch laptop drives have internal cushioning to allow them to withstand some impact, but 3.5-inch drives don't. Give your drive a little more -- or a lot more -- cushioning, rather than hard mounting, and see if that eliminates the problem.
    Just placing the drive on a piece of foam, or on two pieces -- one higher density, and one lower density -- would be a good test. But the foam may present heat issues, so it isn't a good long-term solution. You'll probably want to cushion the mounts.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Go with a read only solid state OS running on flash memory and the problem goes away.
    At least it did for me
    Apr 2008
    so it seems like it was a loose pci card. everytime that i would hit a bump the card would move slightly and of course vists panics and locks up. so i'v screwed it down better and for about 1.5 days nows seem to be perfect...*knock on wood*
    May 2007
    Lakehood, CO
    I saw a guy that took the shocks from an R/C car, and mounted them to a platform that suspended the drive. The springs provided the shock resistance, the oil in the springs provided rebound resistance. This limits the mounting options a little though. (need a little more space for it to move.)
    Quote Originally Posted by blk02si View Post
    Have you seen a 360GB solid state drive yet?
    Quote Originally Posted by racer_X View Post
    360gb IDE hdd
    Or maybe a 120GB?
    Or do you have a spinning HDD for your files and OS only on the SSD? (Which would work BTW)
    edit: Just saw the post above, you were typing the same time I was... Hopefully that's all it is.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Apr 2008
    HAHAHA i would put the os the SSD and then run any music or movies from a USB stick (cheap method)
  1. Need assistance improving boot time - Windows Xp - 12s
    By hidddenh in forum Operating System Optimization
    Last Post: 02-12-2008, 05:15 AM
  2. HOWTO: Install CF on Windows Vista RTM
    By JWise1203 in forum CF FAQs
    Last Post: 02-08-2008, 08:08 AM
  3. Gamma Problem
    By dapure in forum CF Bug Reports
    Last Post: 11-06-2006, 03:33 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. installing windows xp or 98 on 1GB CF
    By arise360 in forum Software & Software Development
    Last Post: 11-11-2004, 07:13 PM
