Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Another blow to my build, help and opinions please!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by yaniv View Post
    I love the cactus
    How are you planning to keep the screens up? If the car shakes even a little the screen will flop right back down like this.
    I was going to put metal plates in the lid and have magnets hold it up and hold it down when its open and closed.
    I'd bet you could get a boneyard dash to work on and eventually give to Brian for fabbing. Is the dash surface steel, plastic or vinyl?
    By the way, this is looking so good that you ought to change the thread name to "Another direction for my build . . ."
    My Durango has a dash with unique texture. I cant seem to find it, so I went ahead and cut the dash. The screens now close 100% percent. the dash is vinyl.
    I love the cactus
    My parents have this weird thing about looking countryish............. I make fun of them all the time. Once again magnets will hold it up....
    PS why is the year 2001? wow Mp3Car forums has weird issues sometimes.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Jul 2007
    Miami
    Well after moding some sunvisor flip downs to hold EBY701s, and working on this project for almost a year (the begginning of my build), I have decided to trash it. The EBY701 had such a thick wire or wires, that it required them to come out of the side of the visors then up into the headliner, this caused the sunvisor to be unable to move side to side to block the sun (very annoying). I also could not take the comments from people that swear vanity is the only thing that matters (the visors had no mirrors). So now I am ordering replacement stock visors......
    My new plan (were I need help) is to have the screens flip out of the top of the dash. The nice thing about the Durango is, it has alot of dash that can be used to hide things. So I wanted to have it so I can cut 2 square holes and make some kind of spring system so that when a user pushes down on the screen when closed, it clicks and makes a spring flip it up. Does anyone have any clue how this is done? Comments and ideas are welcome.
    Thanx in advance!
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Low Bitrate kazzxtrismus's Avatar
    May 2007
    try one of those sunglasses holder type things for a overhead console....im sure you can just use a spring on th eother end of the gear pivot....
    they usually have a 90 degree rotation or 1/4 pie slice with gear teeth on the circumference (apex)....
    they spring load it from one side to let is rotate down nice and "hydraulic like"...so my thinking is that you could spring load it backwards (anti rotationally) as an UP spring...
    to hold a monitor you'll need a stron one and a strong spring but that should work...
    my 06 altima has a nice up swinging door big enough for an 8" screen for sure but probably not heavy duty enough to swing up the weight of a monitor
    06 Altima..SER front bumper.
    CAR PC.....soon to be true!!
    Oshawa Canada!!
    Jul 2007
    Miami
    Quote Originally Posted by kazzxtrismus View Post
    Ill have to try that.... but in the end I think I am leaning towards a 'Flip the d@mn thing open yourself " design, to make the screen very easy to build. I got my dremel off of ebay for $17.00 so Im happy. Has a nice speed setting and alot of attachments except the buzz saws, which I just ordered. Hopefully by the time the saws get here the plastic will be here. I am so excited to be starting this.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    I really think that monitors do not belong in the visors. You should mount it lower somewhere on your dash. Easier+no movement.
    Get MediaEngine !!!
    Media Engine Download
    Jul 2007
    Miami
    Quote Originally Posted by CarComp View Post
    My bad.... here goes me not being specific. Thats actually what I am talking about, I ditched the visor idea because the cabling was a issue to hide and manage. The screens are being fabed to sit ontop of the dashboard, one iinfront of the driver and one for the passenger. I made models out of clay, but the new ones will be made out of abs plastic and use a combo of hinges, magnets and what not to work. Whats nice is that I will not have to cut much into the dash, just a tiny bit to get them to close properly.
    Here some pictures:
    Passenger Side:
    Driver Side:
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Looks pretty good. Interesting that the Durango has a wicker dashboard support -- never saw one of those before. Must be only for here in the tropics, eh?
    I wonder if Brian (Nexson) could simply re-fab the whole top of the dash to fit the doors in and make it look completely OEM.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Make sure that when the screens pop open, they will clear the windshield. It would stink for them to open 85% of the way and be blocked by the glass.
    Also, try them out in the actual car to make sure they don't feel too far away. Mine flips up, but feels just a hair too far away.
    Want to:
    Jul 2007
    Miami
    Quote Originally Posted by rdholtz View Post
    thats what I am hoping.... Once i get the ABS plastic i will design one that he can intergrate into the dash. Only thing that sucks is that i will have to do light cutting into the dash to allow the screen to hold completely and flat.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Jul 2007
    Miami
    Quote Originally Posted by Bugbyte View Post
    yes, that was the first thing i did........ Im trying to account for everything. I would feel stupid if i built them and the didnt have clearance.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Help - Opinions on my DIY LCD case (single DIN)?
    By nxt125 in forum General Hardware Discussion
    Last Post: 04-14-2011, 08:28 AM
  2. LCD Help and Opinions!!!
    By SPyder_Flex97 in forum LCD/Display
    Last Post: 03-10-2002, 12:02 PM
