I just purchases a plastic welder last week. Only tried it out on a few pieces of scrap plasitc i had laying around. I do know for a fact that it will bond your pieces together with 90% strength of the original ABS. There will be sanding and painting envolved. As for as curving the plastic, i think you might could use a piece of curves metal behind your plastic and heat the plastic around it. In my mind, the welder should be able to do that as it uses heated compressed air. I will see if i can give it a try for you this weekend. If it works, i will post pics
LinkBack URL
About LinkBacks
