Results 21 to 30 of 34
Thread: Deville DTS, Monitor Fabrication, -Nexson (Pics)
  1. #21
    Variable Bitrate quantum's Avatar
    Sep 2005
    It's HERE!!!!
    Damn, it looks sweet!!!!
    Special thanks to Nexon and Phoenix imaging. I highly recommend them both if this is the path you want to go down.
    Here are some pics. As you can see, the color matches perfectly. I installed the climate control unit already (too all of 5 minutes). Need to work the LCD into the bezel, which will take me a few days.
    Check it out and let me know what you think! I'll also start up a worklog soon!
  2. #22
    Constant Bitrate roflcopter's Avatar
    Mar 2008
    Ripon, CA
    wow. that turned out really good. big ups to nexson and phoenix imaging
  3. #23
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Dude! it came out OEM
    Very nice!
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  4. #24
    Sep 2005
    you should see it at night when the buttons are backlit.
    The way they got it so glossy and smooth is unreal. It looks wet!
  5. #25
    Sep 2005
    Mounted the screen to the bezel last night and secured the driver board, TS controller, inverter and remote wire to the back. That took a little creative bracketry with wood, ABS strips, foam and "L" brackets and nylon screws (no pics of that yet though).
    Everything is now mounted to the bezel itself, and the bezel just snaps into the orginal factory holes. All wires to the driving board are plugs, so it's simple to connect the power wires, VGA, etc and pop the whole thing right in. Might need to cut away a little of the ABS cage way back in the dash for VGA cable clearance, or maybe get a 90 degree adapter cable.
    I guess this is now my official worklog.
    Some pics. Check out the grain pattern compared to the factory ash tray in the last pic. That is the piece I sent as a sample.
  6. #26
    Oct 2004
    NY
    wow, that came out looking great! awesome job, love the woodgrain, no one would ever belive that you just built that, looks awesome... best of luck with it...
  7. #27
    May 2007
    Quote Originally Posted by turbocad6 View Post
    I totally agree. Looking at it now, i even forgot I made it because it looks liek it came like that!
    AIM: Exus28
  8. #28
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    stellar fab work, looks 100% oem
  9. #29
    Newbie cadillactien's Avatar
    Jun 2008
    Wink Cadillac Deville DTS Custom Wood Grain Stereo Install
    Custom Made Wood Grain Stereo Bezel
    I guess I should of said, I Custom made this.
    Fiberglass & finishing Bondo and a lot of sanding.
    I have a friend that is amazing at painting and it is a 6 stage paint job with a Perl bronzer added.
    Sure I could of just used a lamanit but "It is all about quality" The paint gives it depth and gives the feel of a true factory wood-grain piece.
    If you'd like one this nice let me know.
    I'm in the middle of a unique technical build if you'd like to check me out at http://www.cardomain.com/ride/2440675
  10. #30
    Sep 2005
    Nice bezel. Did you make it, and if so, what did you use for the woodgrain?
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. 1995 Suzuki GSX-R 750 FINISHED! PICS PICS PICS!!!
    By xdjxklusivex in forum Off Topic
    Last Post: 01-08-2007, 06:16 PM
  3. Tidder's Suncrap Whoring
    By kamikaze2112 in forum Off Topic
    Last Post: 09-07-2006, 01:07 AM
  4. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
