Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Deville DTS, Monitor Fabrication, -Nexson (Pics)
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    welcome, BTW Mike, you should be getting this tomorrow hopefully
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    May 2007
    ok
    AIM: Exus28
    May 2007
    Cool Deville DTS, Monitor Fabrication, -Nexson (Pics)
    Hey Guys!
    Coming to you with another project. The fabrication is for a member here on the forums. Mike is his name and he had me do some work for him on this panel. The project is a bit different in the fact that I will not be finishing it. Actually, Mike is having it finished in a wood grain finish to match the rest of his Cadillac's interior.
    The Website to where he plans to get this done is as follows: http://www.phoenix-image.com/Hydrogr...Burlwood02.htm
    As for the fabrication, the monitor Mike is using is not a Lilliput but he opted for the Lilliput case because the dimensions are exact for his monitor he has. Since it was a different screen we were able to do away with all the buttons and I was able to make slight changes to the bottom of the bezel.
    To fill the voids on either side of the screen I used wood sticks that were fully glued in with CA glue, which was then followed by Epoxy putty which is stronger then any filler. I used the putty on the back as well after I CA glue the bezel into the panel. From here I moved on to Duraglass short strand filler, and then any pinholes were filled in with Rage Xtreme. To top things off I used Slicksand High Build primer. From here I went through about 4-5 primer-ing and high grit sanding "sessions." Finally, I was able to wet sand in the last stage.
    I left the panel perfectly smooth and ready for whatever needs to be done for the woodgrain, I believe that they most likely use a film to cover the panel, but it has to be perfect before leaving here.
    I hope Mike comes back and posts pictures once it is woodgrained.
    Here are the pictures from the work!
    AIM: Exus28
    Variable Bitrate quantum's Avatar
    Sep 2005
    Damn that looks nice! I wish I had a DTS!!! Oh wait, that's MY panel, LOL. Can't wait to see it live and in person. The Phoenix Imaging process will make the whole bezel and climate control match the woodgrain in the car. That process takes about 2 weeks to get it back.
    I will definitly start a work log for Caddyputer 3.0. This install is going to be SO cool, cus I plan on incorporating the night vision HUD into it. details posted soon.
    Nice job, Brian! Many thanks for banging it out so fast.
    Hey, how about a pic of the back view where the LCD mount is (you can e-mail it to me or post, either way is fine.
    May 2007
    Quote Originally Posted by quantum View Post
    Thanks man!
    Too late for the pic, already packed up and ready to go!
    AIM: Exus28
    Low Bitrate yaniv's Avatar
    Jan 2008
    This looks sweet!
    I'm wondering about the materials you used.
    (I'm planning to make a similar project and I'm not sure what to get)
    May 2007
    Well basically every material i use has its own separate purpose and each material is used only on a certain step in the order of the way the panel is made. Basically the epoxy putty fills in everything rock hard. This is what gets sanded down. Then I use a Reinforced body filler which i get most of my smoothness out of, then with pinholes I use Xtreme to get it right. And I almost forgot, CA Glue is used to fuse all the pieces together before any filler.
    Keep in mind, I have been doing this for over 3 years and have come to use all the correct and best products out there for my products/projects and they do show. You can always get the run of the mill materials at wal-mart, they will all do the same thing, but the quality isn't up to par.
    AIM: Exus28
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    that looks sooo dang good! im going to save this are the products that you explained above all the "exact" names of them? can i get a list? in order of use with a picture maybe?
    Jan 2008
    Quote Originally Posted by eric_barcus View Post
    Yes I would love to get the names too.
    May 2007
    Quote Originally Posted by yaniv View Post
    CA Glue
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8507.jpg[/media]
    Epoxy Putty
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8512.jpg[/media]
    Epoxy Putty Sanded Down
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8517.jpg[/media]
    Duraglass (short strand reinforced body filler) other names "Bondo Glass" (cheap brand)
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8520.jpg[/media]
    Duraglass sanded down (duraglass gallon in picture)
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8523.jpg[/media]
    Rage Xtreme Lite-Weight Body Filler (light blue) Used to get final smoothness
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8527.jpg[/media]
    Duplicolor High Build Primer
    [media]http://i36.photobucket.com/albums/e25/nexson1/2nd%20album/IMG_8539.jpg[/media]
    AIM: Exus28
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  2. 1995 Suzuki GSX-R 750 FINISHED! PICS PICS PICS!!!
    By xdjxklusivex in forum Off Topic
    Last Post: 01-08-2007, 06:16 PM
  3. Tidder's Suncrap Whoring
    By kamikaze2112 in forum Off Topic
    Last Post: 09-07-2006, 01:07 AM
  4. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
