Results 1 to 8 of 8
Thread: What is the flexibility of bondo?
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i have made and enclosure for my carpc, i basically took one of the back cubby holes and made a mold around it, after 5 layers of fiberglass i have a pretty solid mold with the correct shape to fit the car but i need to make it smooth and sand it to then paint it, but i remember someone saying that bondo cracks easily, my mold is solid but it has a little flex on it so i don't know if bondo will crack, does anyone know of a product like bondo to smooth surface but that is flexes aswell?
    Mar 2006
    Colorado, but Canadian!
    Just sand the crap out of the fiberglass
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by 2k1Toaster View Post
    i wish it was that simple, i have high and low spots because the cubby hole from the car had an outline to it, i just want to make it completly smooth and to hell with the outline, i painted it with a flat black so i could see the high and lows better and there is no way i can sand the fiberglass to smooth i have to use a filler.
    on a brighter side after reading the sticky on fiberglass tips i stumbled on to a thread that showed you can mix the body filler with fiberglass resin and it will turn the bondo into a substance that has enough consistency to brush on and not have to use a spatula to apply.
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    Don't use Bondo, it's got virtually ZERO flex. It will crack.
    Use bumper repair products, such as 3M bumper repair, or Dynatron 660. You can sand it within 15 min, or so.
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    yes DEFINITELY dont use bondo if u want something flexible.
    Live mp3Car Facebook Chat
    Mar 2005
    Rockledge, FL
    how about evercoat rage?
    Aug 2007
    Utah
    Quote Originally Posted by Injector View Post
    I've never used the stuff myself, but it's quite popular with a lot of folks here on the forum. I can't speak for how flexible it is, or not. I don't know where to get it anywhere around me, so I just use the bumper repair epoxy.
    Greedy
    -Adj.
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Mar 2005
    Rockledge, FL
    well here's a random question, if i do mix the body filler to the fiberglass resin would that give the body filler the same strength as the resin itself?
    as shown here
    http://www.the12volt.com/installbay/...TID~74519~PN~1
  1. What is Bondo..
    By ryan-neil in forum Fabrication
    Last Post: 04-07-2006, 06:22 AM
  2. Bondo Applicatin Question
    By jmciver in forum Fabrication
    Last Post: 02-16-2006, 07:58 AM
  3. used too little hardener for the bondo
    By fullgrown in forum Fabrication
    Last Post: 08-01-2005, 03:37 PM
  4. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  5. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
