Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Fab Question
  1. #11
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Right it might be strong as steel, but that is worthless if used on plastic properties. CA Glue or Duramix 4040 is really the answer.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  2. #12
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    Quote Originally Posted by blackcobra487 View Post
    My question is, if I get it to hold together, can I just cover the mold with some cloth and fiberglass it? This would keep me from starting over and would keep it looking the same since I was quite happy with it. Does anyone think this would be a bad idea? I feel like it would use my current mold as a mold for the fiberglass, but I've never worked with this stuff before.
    If it's just surface cracks, then you would be fine doing that. If it's structural cracks then you will have to redo it, otherwise it will fail later down the road.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #13
    May 2007
    Post pictures, most likely they are structural cracks unless you really have the bondo piled up and they are just surface cracks
    AIM: Exus28
  4. #14
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Yeah, I have to agree with these guys. My idea of drilling holes might be interesting, and could -- theoretically -- work. But if the JB Weld isn't grabbing onto the plexiglass, then I'd follow their advice and choose another material. Yep, it's extra work. But I bet you'll be happier in the long run.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  5. #15
    May 2007
    Lakehood, CO
    The holes thing would work sort of, and would create a better mechanical bond, but you'll want a chemical bond to prevent temperature cycle damage and retain flexibility.
    It would be a little work, but I think rebuilding the whole piece the right way would be better than having to redo the one you have now.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  6. #16
    Sep 2007
    West Springfield, MA
    I can assure you that they are structural cracks. Does anyone know of a glue that would bond plexi glass? I used plexi because it was easily available, so I would like to stick with it.
  7. #17
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    acetone will work to bond plexiglass. or better yet take some scrap, dissolve in acetone, and use that as a glue. glass jar or a PP bottle works well as a container. remember to use real acetone, and not fingernail polish remover. you can buy it in the paint section of a hardware store or homedepot.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  8. #18
    Sep 2007
    Thanks, I'll give that a shot.
  9. #19
    Jun 2006
    Quote Originally Posted by seanz0rz View Post
    What he said...
    check this thread for a pretty good explanation...
    http://www.ocforums.com/showthread.php?t=95900
  1. heavy-duty OBD standards support question
    By Michael2006 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-07-2007, 05:13 AM
  2. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
