Results 1 to 10 of 19
Thread: Fab Question
    Sep 2007
    West Springfield, MA
    Fab Question
    Ok, I just finished my first install and the piece I made began to crack, big time. It's an 03 Accord, and I mounted the screen where the center vents used to be. Similar to this guys:
    [media]http://www.mp3car.com/vbulletin/attachments/fabrication/45958d1193886835-2003-honda-accord-carputer-fab-pics-08-16-07_1149.jpg[/media]
    Now it's practically falling apart. My question is, if I get it to hold together, can I just cover the mold with some cloth and fiberglass it? This would keep me from starting over and would keep it looking the same since I was quite happy with it. Does anyone think this would be a bad idea? I feel like it would use my current mold as a mold for the fiberglass, but I've never worked with this stuff before.
    Mar 2006
    Colorado, but Canadian!
    Please tell me you didnt make the structure out of bondo...
    What did you use?
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2007
    I made a "frame" out of JB weld and plexi glass, thinking that would be a fairly strong base. I knew not to make it entirely from Bondo. I did use Bondo to make the curves of the final shape.
    Edit: Surprisingly, It's not the spots where the Bondo is that's cracking. It's the corners where the Plexi glass is held with JB Weld. I'm having a hard time believing this stuff can fix an engine block if it can't hold 2 piece of plastic together.
    Mar 2006
    were they different types of plastic?
    anyways, you say you put it where the vents were. Did you plug those vents or is there constantly varying temperatured air blowing accross it? I dont see a problem unless you are cranking the AC though, but it could be a problem if the variations in temperature vary too greatly.
    Sep 2007
    The plexi glass was all cut from the same piece, so no it was the same plastic. But where the plexi meets the old dash piece seems to hold very strong.
    Yeah, the vents are plugged.
    Sep 2007
    I was also thinking of maybe melting the plexi glass together somehow. I would guess a plastic welder would work, but I don't own one. I'm also thinking of somehow redoing the corners (which is where it's cracking) to have more JB weld there.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Is it cracking because the JB Weld epoxy isn't gripping the plexiglass? If that's the case, you might try drilling holes in plexi so the JB Weld can go all the way through it and form bars that lock them together.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Sep 2007
    Never thought of anything like that. Sounds like a good idea. I'll give it a try.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    I dont know why you used JB weld on plastic
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    he probably read this:
    JB Weld Website
    Quote Originally Posted by JB WELD
    What does it bond to?
    Virtually any combination of iron, steel, copper, aluminum, brass, bronze, pewter, porcelain, ceramic, marble, glass, PVC & ABS, concrete, fiberglass, wood, fabric, paper -- just about any porous and non-porous material.
    And thought that it would bond well.
    Plexi is a hard material to use with those kind of products. ABS would have been better. A better solution would be an epoxy made to use with the plexi.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  1. heavy-duty OBD standards support question
    By Michael2006 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-07-2007, 05:13 AM
  2. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
