Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: E39 Bezel from the A to the Z
    Aug 2004
    at home
    Some plaster, some earth, some mastic, a lot of work and time in a lame attempt to build my bezel.
    in black to check errors
    Looks too heavy so rounded angles, thinned lines...
    Now where is my bimmer ?
    Feb 2006
    Vancouver, BC
    dang dude. Way to perfect it. Good work!
    Aug 2004
    at home
    Thank you !
    What you see is only the plug i'm building, i plan to make a mould of it and make it off fiberglass, mastic won't survive to temperature, moisture and vibrations. The piece of fiberglass and gel coat should look better and glossy.
    Aug 2004
    at home
    last stage before fine sanding of the second faceplate including room for dvd player.
    Aug 2004
    at home
    I will see tomorrow under daylight where are still some tiny bad spots, it's too late for now.
    Aug 2004
    at home
    Third and last version of the faceplate letting the dvd player appear in front.
    The primer is too wet but i'll do one more pic with the dvd player inside.
    Aug 2004
    at home
    Some tiny repairs still to be done and some sanding but here to get idea of what it will look like
    Aug 2004
    at home
    Had to rework the faceplate including the dvd player because my car was not available for weeks due to an engine swap but it fits very well, no more space available but it entered anyway
    Now it's finition time
    here the sacrified old dead cd rom to check the deep and space clearance behind it
    Aug 2004
    at home
    A bit more sanding where the primer was not right applied, i paint it and back in the car.
    Aug 2004
    at home
    Next is glossy paint just to see how it looks
  1. Replies: 14
    Last Post: 01-29-2008, 11:16 PM
  2. Replies: 10
    Last Post: 12-18-2006, 09:50 PM
  3. Fiberglassing Gauge Pod in Bezel *pics*
    By jmilin5931 in forum Fabrication
    Last Post: 10-04-2006, 09:04 AM
  4. 2002 Silverado Custom Dash Bezel
    By AZ_Silverado in forum Fabrication
    Last Post: 08-09-2006, 02:46 PM
  5. E39 BMW Dash bezel
    By Mattkins99 in forum Fabrication
    Last Post: 04-29-2005, 12:06 PM
