Results 1 to 3 of 3
Thread: LCD buttons
    Oct 2006
    LCD buttons
    I need to put my xenarc buttons onto the bezel and i have no idea what those buttons are called and the things on top of it is called. Please point me in the right direction.
    Something like this.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Check the LCD thread; you'll find a lot of discussions about buttons there.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I want to do a double din install eventually, so Im just curious. How did you make the install look so nice and stock? Did you just prop the monitor up behind the bezel? Doesnt look like you had to do any fabrication or cutting at all.
    In regards to your buttons did you look at the button relocation sticky here:
    http://www.mp3car.com/vbulletin/fabr...n-buttons.html
    Or did you buy the metal frame and are trying to use the metal buttons with your xenarc?
  1. Buttons on LCD Screens??
    By MyFast in forum General Hardware Discussion
    Last Post: 02-09-2008, 05:31 PM
  2. Replies: 0
    Last Post: 07-24-2003, 03:42 PM
