Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: First time bezel Fabrication
  1. #11
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Quote Originally Posted by ik632 View Post
    I know this is probably the wrong place to ask, but do you have any other info on the integration? Did you input to factory stereo (I see it's still there below the unit).
    Here's what I used to route my sound from my OEM Stereo to my carPc
    1 : http://www.logjamelectronics.com/piex3hon03.html
    2: http://www.amazon.com/PIE-X3-Triple-.../dp/B000PHHPSI
    Simply pick the right model for you needs....and thats it!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
  2. #12
    May 2009
    How's the 700TSV at night? Not too bright I hope (i just ordered one...)
  3. #13
  4. #14
    May 2007
    Ok, THREAD REVIVAL!! (its ok since its mine )
    With all the background and knowledge I gained with this Mp3Car forum, I took everything a part and started my BEZEL again
    This time I'm integrating a MacMini into the Glove Box and going for the Navi Display Bezel.
    I'm still using the same product Dynatron 660 which is the best product I tried so far for plastic!!
    So here is a teaser of my new bezel that will probably be finished and installed next week
    Preparation and first Dyantron work
    After shape is ready....PRIMER!
    Test fit 1
    Test fit 2
    Now, I need to work on the details, there's couple holes here and there but nothing major...it will all disapear with the next sanding step
    I'll simply shape a little bit again with grid 80 and move on to grid 220...when all will be good I'll wetsand with some 1000 and then I'll be ready for PRIMER + PAINTING
    Final Install
    CarPC progress: 95%
  5. #15
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Its all a process from here!
    Take a block to that right side edge with some 220, it looks a little off
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
  6. #16
    May 2007
    ^^Thanks bro It's on my to do list lol
    Final Install
    CarPC progress: 95%
  7. #17
    May 2007
    So here's the evolution...after couples hours sanding priming, sanding and painting
    The final results....it's not perfect cause I really need to put this in the car tonight...I did my best !!
    later for some installed pics (I know that the upper left corner is not perfect atleast I tried....lol)
    Final Install
    CarPC progress: 95%
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
  3. First time fabrication
    By Bellfazar in forum Fabrication
    Last Post: 07-15-2004, 10:56 PM
