Results 1 to 10 of 17
Thread: First time bezel Fabrication
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Hi guys, here's some pictures of before and after my bezel work. I took example on the Turbocad thread, he is the real bezel KING!!!
    SO here it is....
    Car: Acura TL 04 6sp
    FrontEnd: RoadRunner
    Skin: DigitalFX 3.0
    Product used: Dynatron 660 EPOXY, Red primer, Flat Black Enamel Paint
    The screen: Xenarc 700TSV 2008
    OEM BEZEL
    Lets start!! Step 1
    Step 2 After a lot of fitting and Sanding + 3 primer coat
    Step 3 Test fitting
    Step 4 Painting
    Step 5 - FINAL INSTALL
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Looks OEM -- fine job. And you couldn't pick a better guy to emulate.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Constant Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    sweeeeeeeeeet how about some step by step so we can learn oh masterful one...
    May 2007
    Final Install
    CarPC progress: 95%
    Dec 2005
    Raleigh, NC
    I know this is probably the wrong place to ask, but do you have any other info on the integration? Did you input to factory stereo (I see it's still there below the unit).
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
    May 2007
    Yes I kept the factory stereo and used a small aux device to get the audio from PC to Stereo...I'll find some time to explain tonight or tomorrow night....
    Final Install
    CarPC progress: 95%
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    What paint is that?
    Play with it, 'til it's broke.
    May 2007
    I used Flat Black Enamel paint (engine paint). Been a year now and it didnt chipped or changed color ....just perfect!
    Final Install
    CarPC progress: 95%
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    I'm impressed! That paint turned out VERY OEM! (as did the entire project, but from the pic angles, the paint looks surprisingly perfect!)
    May 2007
    The paint looks just like OEM and even better in my opinion, the only thing that bothers me is that I didn't quite finished my bezel the way I wanted....I'll have to get back on it when summer comes back!! Thanks for the comment man, I appreciate!!
    Final Install
    CarPC progress: 95%
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
  3. First time fabrication
    By Bellfazar in forum Fabrication
    Last Post: 07-15-2004, 10:56 PM
