Generally when adding/modifying a trim panel you want to use an automotive filler product such as bondo glass. It is strong, durable, sandable and paintable. You can also wrap it with vinyl. It looks like you used a two part epoxy to attach the dvd to you console which could be a problem because epoxy is usually not sandable or easily removable.
LinkBack URL
About LinkBacks
