Slot-Making Update
This was posted in my worklog, but pertains to slotting, so I've duplicated it in this thread.)
Originally Posted by
monkeyracer
I really think that a slot punch would be the way to go, but I just can't find one online. I thought I saw one on Harbor Freight, but it's not where I thought, and searching brought up 1000 results.
I found a terrific punch at Harbor Freight, but it's only for round holes. The punch -- at list price -- is $35 with the stand.
(I reviewed that punch in post #13 of this thread. Pictures, links to it, and results are there.)
I really thought it was going to be the answer to this slotting thing, once I got a slotting punch and die set for it. Then I called Roper Whitney to ask about prices. Hoo, boy! The only stock slotting punch and die set is 1/4" x 7/16", and it's $140.40. They custom make anything else for a few dollars more; the slotting punch and die set I'd want, 3/16" x 1/2", is $147.80. I just wouldn't use it enough to justify that expense for the low-volume stuff I do.
I'll keep on using the punch for round holes. It makes sheet metal work soooo much easier. But when it comes to slots, I'll use the punch to form the end holes and keep on using the cutoff tool to cut out the metal between them. As much as I like the idea of instant slots, I'm just not willing to pay that price for them.
monkeyracer
I think if it's a low run project, you might search for waterjet cutters nearby and see how much they would charge.
A search on google maps using keywords: "waterjet loc:
Palm Beach Gardens, FL" came up with 73 results.
The place near me charges a minimum $60 per job, but if you're buying milling attachments and hand press punches for a little less, you might as well just cough it up and have it come out exactly perfect. Your cutter might have a lower minimum. Usual tolerances are as low as .01 inches. I'd say have them slot it and cut it, then you can bend it (some shops will bend for a couple extra bucks.)
I'm totally into DIY, but there are some things that are just not worth the effort.
I'm into DIY, too. I like to do the tinkering. For most of what I do, I'm experimenting with sizes and shapes right up to the last part I produce, and my car is a drivable prototype; every modification is a one-of-a-kind or two-of-a-kind thing.
Once I've solved the problem, I want to move on to the next challenge, not make a bunch more of what I just did. Taking the time to get the designs into a CAD program and get them produced on a waterjet is simply too production-oriented for me. I'd just as soon turn it over to a production shop and go on tinkering. I've had some requests for duplicates of my parts, so I'll keep that waterjet process in mind.
