Its not bad, but it needs alot of sanding. Seeing how rough it is, I would used 36 grit in some places just to get the general shape.
Here are some pics I took last night:
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
Is there an easier way to put it on smooth?
Should I put another layer on it then start sanding? I just don't want to sand one spot too far then have to start over again.
Since it is shapped very tightly, i use my finger to put it on, then sand it off, prime it to see how evenly it looks and then go from there
AIM: Exus28
I got some sandpaper last night and went to town, wow this is going to take a while and you burn through sandpaper so quickly.
Nexon, I have a question. Someone told me to get an IR 90* angle grinder for my air compressor to help speed up the process.
Have you used one of these on this type of project, does it help?
Ok, you dont need a die grander for such a small project. Everything has to be done by hand by sanding unless you use a dremel with a small sanding wheel to get into tight places, just keep on sanding and sanding, it will shape up eventually.
AIM: Exus28
Ok will do.
Out of curiousty what type of bit should be used for the dremel? I tried a few before, the ball, the pointed tip, the odd shaped ones and never really found one that worked very well. I tried the wire brush and it worked ok.
i have all different sizes that i use for different things, it really depends on what you want to do
AIM: Exus28
Cool, just wondering. I'd actually like to figure out what the rest of the pieces in my dremel kit are used for. I just use the dremel for cutting small things.
What type of paint do you use to get that oem interior look?
OEM Texture, OEM satin black
AIM: Exus28
