Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Fiberglass help. I suck at this.
    Apr 2005
    So I'm making an attempt at fiberglass and so far nothing is going right.
    I have a 97 eclipse. I'm trying to cover my foglights, so I took out the bezel and put fiberglass over it. Did a few layers and for some reason the fiberglass just popped off the bezel.
    I tried it again and this time heated up the plastic and still no luck.
    Now I'm trying to make a-pillar gauge pod that holds 4 gauges. I have an a-pillar that holds 2 and bought a universal one to go on it. I put 2 screws into it and fiberglassed around it. Stupid thing just popped right off.
    Now I used a hot glue gun, then put fiberglass, then tried to do fabric over it. No matter how I tried I could not get the fabic to lay 100% flat, I got a lot of air bubbles.
    Some of the fiberglass pulled off, but it seems pretty secure now. I started to sand it. It felt smooth so I did a light coat of primer to make all the imperfections stand out. I sanded some more, and now I'm going to get some type of filler to smooth it all out. Should I use a bondo with flex? A straight bondo? Bondo,flex and fiberglass?
    What should I use?
    And why does the fiberglass keep popping off?
    If this one doesn't come out good, I may see if I can just get someone to do it for me. I've tried over and over again, and I must be doing something wrong.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Fiberglass "pops" off because fiberglass does not adhere to plastic. It has to roughed alot. There is a whole process I follow to make it work.
    I can finish it the correct way if you like, but you have to pay
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Use epoxy resin and it will stick
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    May 2007
    Quote Originally Posted by v8 scimitar View Post
    Even so it needs to be roughed up still
    AIM: Exus28
    Apr 2005
    Ok, so this is where I'm at now. I started over again. I got some plastic epoxy and used that to hold it to the pillar.
    So far so good on that. I then got some filler (bondo), mixed that and a hardner, let it dry and started to sand it. Geez it's a lot of sanding and it's not coming out as perfect as I would like it to.
    I used the bondo around the edges, do I need to cover the entire thing in bondo, will that be easier?
    Nexon, I may be contacting you shortly if I can't get this right.
    May 2007
    It is jsut hard to explain if you have no pictures.
    Do you stretch fleece, how many layers of fiberglass mat did you add?
    Did you sand down the fiberglass first to get it somewhat even?
    AIM: Exus28
    Apr 2005
    Well that was before. Now I used the bondo filler and expoy to hold it in place.
    I'm sanding with a 80grit brick and an electric sander, then moved up to a dremel.
    I put on a thin coat of paint to find all the imperfections.
    How should I continue sanding? By hand, dremel, electric sander?
    May 2007
    By hand is the best way to sand
    do 80-120-22o then prime to find imperfections, then keep continuing the 220-prime stage until perfect, then 400 wetsand primer
    AIM: Exus28
    Apr 2005
    Well I found a spot that had a deep goudge, so I put more filler over it. Doing it by hand now.
    Am I looking at a few hours of straight sanding? Any tips? I'll try to get some pics up tomorrow.
    May 2007
    sanding can take about 3-4 days. I have spent days sending just small projects.
    Change sand paper often
    AIM: Exus28
  1. Fiberglass subwoofer box.
    By 0828546333 in forum Fabrication
    Last Post: 04-20-2009, 07:27 PM
  2. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 04:30 PM
  3. Fiberglass Alternative?
    By FiReToY in forum Fabrication
    Last Post: 04-24-2008, 09:24 AM
  4. ***jojor512's fiberglass fab guide***
    By jojor512 in forum Fabrication
    Last Post: 12-12-2006, 01:05 PM
  5. 03-05 Honda Accord Fiberglass False Floor...WIP
    By 98EXL in forum Fabrication
    Last Post: 03-20-2006, 09:11 PM
