Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 2007 Mini Cooper 7" Screen Fab Help
    Constant Bitrate lacning74's Avatar
    Apr 2008
    This center console is a pain. Moving the volume knob and CD is not possible since it is integrated into the speedo disply above. I'm thinking of installing the screen as pictured below. I'll need to move the AC controls and toggle panel all the way down. I'm not sure how I'm going to physically cut and paste the sections neatly. I'm looking for tips and suggestions. Thanks!
    Apr 2008
    Well, I purchased an Exacto solder hot knife to cut as straight a line a possible between the volume knob and A/C controls. The plastic there is very thin. I tested out my dremel on another section and it was a little rough and destructive. It would be fine if I just needed to cut a hole for my screen, but I also want to preserve what I cut out as much as possible.
    Low Bitrate vtecfelon23's Avatar
    Dec 2007
    Baltimore
    A mini is a tough project, i would really like to see where you get with this. My buddy has one and want to put a pc in, but space is soo limited in those things. You should probably consider removing the lighting switch panel and making your own, as for the ac, i think you should have some room under the monitor, once it is in. A hot knife seems to be the cleanest way to do things, and some abs cement.
    Apr 2008
    I did some cutting with a Exacto-knife solder. Still need to pick and sand the edges clean. What's the best technique and type of sand paper?
    Here is where I'm thinking of relocating the A/C and toggle controls.
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    Nice work so far.
    The moulding is ABS so ABS cement is the way to go, or have you tried ABS welding using the hot knife and some ABS stock?
    The controls should move OK if the wiring is long enough but usually you can get more slack by unwrapping the harness tape.
    PLEASE post up your work as the MINI community would be very glad of the tips.
    MINI COOPER S PRO
    Apr 2008
    Quote Originally Posted by chrislamb View Post
    Nice work so far.
    Thanks! I'll look into the cement. I really hope the wire reaches. I tend to do things backwards with a baby and a toddler in the apartment and no garage with my car parked far, far away. If things are looking good, I'm probably going to have to get a "professional" to cleanly weld things together and bezel my screen. Not sure I have the time to learn how to weld, mold, sculpt, sand, and all that stuff. I really wish I did, though.
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Since your working with plastic, take a look at the epoxy Dynatron 660. Its really easy to apply and sand. It could help you a lot to blend the face of you screen with you OEM Bezel. It looks like a really big relocating project, so good luck and don't give up!!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Nov 2007
    Warwick, UK
    Oooops, I was wrong.
    In fact the moulding is ABS/PA. That is a blend of ABS with PA added.
    ABS cement might struggle to grip into it so I would suggest you use a 2 pack structural adhesive and flame the mouldings first.
    Sorry for my mistake.
    MINI COOPER S PRO
    Apr 2008
    Thanks for the tips and encouragement! After some more cutting, here's what I'm thinking. It's going to need a lot of work to blend together, especially the bezel.
    Nov 2007
    Warwick, UK
    Looking good.
    Hotmelt glue is also very useful for inside surface construction.
    As far as I know you are the 1st to try this, when you finish the MINI community will be very grateful.
    Keep up the work.
    MINI COOPER S PRO
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  2. My Custom 1.5 DIN 7" Screen Install!
    By InfiniteReality in forum Fabrication
    Last Post: 03-04-2008, 11:20 PM
  3. 7" Dynamix (LinITX) LCD - white screen problem
    By xraycat in forum LCD/Display
    Last Post: 10-22-2007, 01:43 PM
  4. MINI Cooper Cabrio, Mac Mini
    By FireAnt in forum Show off your project
    Last Post: 05-02-2005, 11:44 AM
  5. 7" Lilliput VGA Screen $200
    By Rundell in forum Classified Archive
    Last Post: 11-22-2004, 08:04 PM
