Results 1 to 8 of 8
Thread: Need to buy or make a bezel for an 8" screen
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Well, after many hours of pondering this, I simply can't wrap my head around any concrete ideas. I'm in a bit of a conundrum.
    I have an 8" touchescreen that I put into my 2008 VW GTI. With an aftermarket double din radio kit, I managed to get the screen is securely and it looks pretty good. However, it still doesn't have the "clean" look I'm going for. Here's what it looks like right now.
    As you can see, there's a few issues I'm having. The first, is that the mounting kit needs to be sanded and painted were it has a couple of scratches from grinding and cutting on it to make the screen fit. That's no problem, I can do that part myself easily.
    The second issue is the screen bezel. Since it wouldn't fit with the factory bezel on, I had to remove that. The problem is, the stock bezel is what holds the touchscreen overlay to the LCD itself. Without the bezel I had to use electrical tape to hold the overlay in place on the LCD. Not only does it look like crap, I have no idea how else to do it.
    I was thinking about buying another bezel. Is there any place to buy bezels that would fit? Or any one with a bezel laying around they don't need?
    If I can't buy a bezel can I make one? I was thinking about making one out plastic bits I have laying around. If I made the bezel, glued the plastic bits, used some filler and then sanded everything smooth before painting would this work? If so, what kind of materials would I need to do such a thing?
    When it comes to fabricating anything other than MDF I'm a noobie. Any help would be greatly appreciated.
    Also, if anyone has any other ideas let me know. This is the last bit of work to do on my GTI and I'm at a loss.
    Edit: Also I wanted to add that you can see how the dash is actually 2 pieces around that mounting kit. This makes it even more difficult because I can't really get a good mock up with the screen out of the car.
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
    Sep 2008
    It looks like the screen is just too big height wise.
    I would go with a 7" screen and mold it into place on the double din kit and call it a day.
    If you decide to keep the 8" screen, try to mold the front facia of the screen onto the double din kit, but it doesn't seem possible because of the height.
    Dec 2005
    Grand Blanc, MI
    Yea, I realize the size is less than ideal. However, I'm kicking some ideas around in my head. If I could just find some form of 8" screen bezel to go over the screen made from ABS or metal (aluminum, etc.) that was thin enough, it would work ok. However, I don't have the tools nor materials to make this myself.
    Any idea where I can find an 8" bezel that would work like this:
    If I could find a thin piece of ABS or aluminum that was cut out for the screen, I could make a bezel from it. It doesn't even need to hang over on the top or bottom, just on the sides to fill that gap between the screen and the mounting kit. Seems like it would be easy enough but I can't find anything on Ebay or google to fit the bill.
    Anyone on here who could fabricate this for me?
    CarPC:
    Sound System:
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've got ya covered, and I'm local! Responded to your PM, this type of job is what i specialize in, fabricated aluminum parts.
    Sep 2008
    Why don't u use the plastic facia from the screen itself?
    Dec 2005
    Grand Blanc, MI
    Quote Originally Posted by fabworks View Post
    It appears to have been misplaced at some point unfortunately.
    CarPC:
    Sound System:
    Dec 2005
    Grand Blanc, MI
    Quote Originally Posted by blk02si View Post
    PM replied Joe, thanks!
    CarPC:
    Sound System:
    Jan 2010
    I am in the same boat as him and need a similar bezel in metal or plastic. When I bought the screen it was already disassembled and the pieces disposed of.
  1. Boot up 3 times @ 800x600, 4th time at 800 x 480???
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-31-2008, 09:31 AM
  2. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  3. My Custom 1.5 DIN 7" Screen Install!
    By InfiniteReality in forum Fabrication
    Last Post: 03-04-2008, 11:20 PM
  4. Review: TView 8" LCD Widescreen Touch Screen 56k Beware
    By AcuraTLFan in forum The Review Palace
    Last Post: 01-30-2008, 03:01 PM
  5. I have no touch screen... how do u make an interface?
    By domdino in forum General Hardware Discussion
    Last Post: 10-07-2002, 09:39 AM
