What a project, good luck.
For staight lines i found it best to use a hack saw; the wide blade kinda keep it going staight. What i would do is cut oversize ("leave the line")then lay a sheet of rough sand paper on a flat surface then run the (bezel) cut back and forth against the sand paper. By the time you sand it down to the line you really want, it should be pretty darn staight.
LinkBack URL
About LinkBacks
