Results 1 to 10 of 20
Thread: Help with rounding out edges on MDF!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have finally started on center console #2. The first one was to awkward, to square and just didnt match my car.
    I built the new one based on the 2009 rear center console, but mine is bigger and will be more geared towards my interior. Here are some pictures:
    Here is the bottom:
    As you can see its very square with all edges being square. I was wondering what I have to do to make all the edges rounded? Keep in mind this is MDF, can I sand it the same way I would regular wood? I am very lazy and want to take a electric sander to it, but dont want to mess this thing up. Does anyone have any dealings with working on MDF?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    Aug 2008
    Guam
    I'm pretty sure you can just use a router or jigsaw for making the edges rounded and then sand down with a sawing motion....
    I'm not expert carpenter though.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by HiJackZX1 View Post
    Regular wood tools work fine with MDF, but they dull much faster. Carbide bits and blades are best, and are used by cabinetmakers who use MDF.
    To make corners round, you could use a sander, but routing works well to remove a lot of material relatively fast. Practice on some scrap, like your old console. Before you use the router, be sure all the joints are glued well, and take out the metal fasteners so the blade doesn't try to eat them.
    If you want large radius corners, you can glue a triangular corner block on the inside of the corner; that gives you the ability to make a huge radius, more like the radii in the rest of your vehicle.
    If you don't have a router, hit Harbor Freight and get a cheapy; spend your money on a good router blade the shape you want. Go slowly with the router so you don't tear up the bit or the workpiece, or burn out the cheap router's motor.
    Be sure to use goggles. The router will throw little MDF chips everywhere, and those little buggers are hard and hot. Eyes don't like 'em. If you have hearing protection, that's good too. The router makes a helluva loud whine.
    But you won't whine at the result. It'll be sweet.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Jul 2007
    Miami
    Quote Originally Posted by rdholtz View Post
    MP3Car is acting up, darn thing didnt tell me that someone replied! A router most def sounds like the way to go. I still dont understand the triangle block thing!
    4x 10inch Tablet
    Feb 2007
    netherlands
    He means that you can sand away more metarial than the width off your mdf.
    The bigger the pice of mdf you glu on the inside, the more metaral you kan sand off.
    This is my subcasing, also of mdf, and i did use the traingel pieces. (sory, don't have a picture of the inside.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Always wear a mask when working with MDF indoors. That fine dust will make you really sick.
    Newbie miko55's Avatar
    Jun 2007
    Ljubljana, Slovenia, Europe
    How you can reinforce corner, and then make a bigger circle radius of edge.
    Round corners you achive profiling cutter head.
    For single time usage this one will do:
    Profesional
    Advice: Go to you local hobby shop and ask them if they can help you with roundig of edges, with some profesional cutter machinery and blades.
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by miko55 View Post
    How you can reinforce conrner, and then make a bigger circle radius of edge.
    In the first image, look at the triangular piece labeled "corner block". Now imagine a solid piece of wood that's much longer, not just a 1/2 inch deep, but instead running the full length of the joint. We could cut away much of the outside of the corner and thus make it round.
    The cutter head you pictured is fine, but it's more complex and expensive than necessary; that's a universal profiling head capable of all sorts of intricate work. For corner rounding, we can use a simple router bit with a 1/4-inch to 1/2-inch radius, depending on how round we want the corner. Such bits -- with carbide blades for MDF -- are available at hardware stores and Home Depot.
    Jul 2005
    get yourself a router with a bullnose bit
    or buy this tool called the fastbreak My dad invented it. Its a sander in a V shape and it has sandpapper on the inside and you run it up and down the edges of 3/4 inch mdf
    Jun 2007
    Tools on pictures are semi profesional or profesional. They were ment as guideline.
    Slovenia, Europe
    best on-line radio
  1. MDF Screws
    By thekl0wn in forum Fabrication
    Last Post: 10-10-2008, 10:18 PM
  2. Fiberglass and MDF sub enclosure walkthrough
    By monkeyracer in forum Fabrication
    Last Post: 05-19-2008, 02:55 PM
  3. New sound setup.
    By jaloos in forum Car Audio
    Last Post: 08-30-2007, 08:56 PM
  4. MDF PC Case. (Éire)
    By ryan-neil in forum Fabrication
    Last Post: 07-11-2007, 11:12 PM
  5. MDF Rings
    By Giwo in forum Fabrication
    Last Post: 03-23-2005, 04:42 PM
