Results 1 to 10 of 10
Thread: Wanted: Someone to do my Bezel Modification
    May 2008
    I have a 07 Chrysler Sebring. I have a spare radio bezel. I need the opening to be 4" tall by 7" wide for my Guru Carputer. The current radio opening is too short and too wide. I dremeled out the height so I could run the Guru in the car while testing it.
    If you are good at bezel work and are interested in another bezel project to work on contact me. Obviously I will pay for the work.
    Jason
    May 2008
    What I am looking to do is have the radio area made level (it currently goes inward as you can see from the pic) and extend to the sides of the Guru. The bottom side of the radio section will need to be slightly built up in the middle to make it level with the bottom of the radio as well.
    Jun 2008
    Why not just go to a hobby shop (unless none available) and buy some of their modeling plastic. The modifications look simple and then buy you some bondo glass if you need a high build and/or something like rage gold for a low build/finishing layer. Get some paint and you're done.
    May 2008
    Quote Originally Posted by derek0606 View Post
    I already tried working on it. Don't have the skills, time or patience for it. Rather go with someone who has experience and can produce a factory look.
    Jason
    Jun 2008
    I know a few friends like this. I would help you if I didn't have so many projects of my own.... Plus I have been one handed for a month now. This delays me more!
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by kb9kst View Post
    Jason
    Check out Nexson's thread here in Fabrication.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    Quote Originally Posted by rdholtz View Post
    You should try Nexson, He has done work for a couple (that I know of) members on this forum. Check out this LINK, he's trying to get his name out there and posted a video for recognition. He also has other work posted in fabrication to check out.
    If you cant DODGE em, RAM em.
    Oct 2006
    being that its entire unit all as one, and not just a screen i would work on mounting it into the car first, then re-working the bezel around that. Its not too difficult to make that look nice, however if someone does it for you and then where its placed in the bezel doesnt line up for mounting then your screwed.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Check your PM, I sent you a technique to relay over to me the way you should make a template for perfect fitment
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    May 2008
    Thanks to TURBOCAD6 this is what I ended up with.
    THANK YOU!!
    Jason
  1. Replies: 1158
    Last Post: 04-06-2011, 09:38 AM
  2. 1999 Honda Civic Bezel
    By wjc04wrx in forum Fabrication
    Last Post: 01-19-2010, 12:24 AM
  3. Secure LCD to Bezel
    By TeamRSX in forum Fabrication
    Last Post: 02-15-2008, 03:16 PM
  4. Lilliput bezel broke away from console
    By peecee in forum Fabrication
    Last Post: 03-31-2006, 06:49 PM
  5. FS - Custom made Car PC Xenarc Bezel for 05+ WRX/STi
    By RR BuGGz in forum Classified Archive
    Last Post: 11-29-2005, 01:13 PM
