Results 1 to 10 of 10
Thread: Need finding switches
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I just got a new mini itx board and am planning an overhaul of my carpc. I am planning to make a custom center console to replace my stock console. I plan to include the head unit, mini itx board, m4 psu, dvd rom drive, receiver for wireless keyboard, usb hub, and various switches. I have got the basic plan down but need a little help with the switches.
    I want to add the following switches to my new console:
    Fog Light
    Power window switches
    Amp
    PC
    Monitor
    My power windows are after market. They came with switches. My power switch for the pc came with the auto power on module I purchased from W3bMa5t3r. I purchased switches for the rest of the items at an auto parts store. They are all different switches, mounted between my seat and the floor. I would like to replace all of them with matching switches when I build my new console. I am looking for smaller switches with some type of lighting. I don't like the looks of toggle switches. I like the "ROUND ROCKER SWITCH BLUE LED" from the store but I don't know if they will work for my needs.
    Anyway, I have found lots of switches for the fog, amp, and monitor. The problem for me is the pc and power windows. Are the power window switches special? Can I add a switch to my Intel D945GCLF Mini-ITX Motherboard and m4 that will act like a power switch on a desktop?
    Any input will greatly be appreciated.
    Constant Bitrate damarble's Avatar
    Jan 2006
    Spokane
    These might work, only thing is I don't know if they return to center automatically.
    http://www.allelectronics.com/make-a...DIODE/-/1.html
    I'd probably just hit a junkyard and take a bunch of matching switches from another vehicle.
    {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
    MY INSTALLATION LOG
    Nov 2007
    North Central PA
    Thanks for the help. I think that would work for the windows. However, for the other items, I'll have to find different matching switches. The junk yard is a good idea. I'll have to check it out. Thanks for the help.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    If you can't find what you want there, check the Mouser catalog. There are about a bazillion different types there. The catalog is online as PDFs, or you can order the whole book, which is about 1-1/2 inches thick. Some of the prices are surprisingly low, too.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Nov 2007
    North Central PA
    I found all the switches that I wanted. But I want to make sure of something. Can I add a momentary switch to this motherboard when used with the M4?
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    Dec 2008
    Check out http://www.carlingtech.com/ for a huge selection of rockers that work well for custom setups. I've used them on buggies, jeeps, and hot-rods in the past with great success.
    They are available with may different colors, words/pictures, styles, momentary, on/off, 3 position, etc.
    You will have to find a supplier as you cannot buy them direct but locally I can find them at Napa and online an example is http://www.waytekwire.com.
    Elsewhere
    Quote Originally Posted by rizaydog View Post
    You want a switch on the ACC line to turn it on/off. This will trigger the M4 to turn the PC on/off when the engine is running.
    T basically acts as a valet switch for the PC. If you turn the switch off and the engine is off, the PC will not boot up when the engine is started, as the PSU would not be getting voltage on the ACC line.
    How about the Wiki?
    Nov 2007
    North Central PA
    This line doesn't carry the higher current to the psu correct? The switches that I found only carry like 15 amps. The draw on the ACC line should be fairly small?
    Elsewhere
    Correct. The line is only used to sense the ignition state, and carries very little current.
    How about the Wiki?
    Nov 2007
    North Central PA
    Great. That will be perfect. Thanks.
  1. Custom Power Switch(es) Idea
    By rightsidenov in forum Power Supplies
    Last Post: 09-14-2008, 01:14 PM
  2. Soft touch switches?
    By sebberry in forum General Hardware Discussion
    Last Post: 09-28-2006, 04:51 PM
  3. Xenarc LCD Switches inputs
    By zaid175 in forum LCD/Display
    Last Post: 09-16-2005, 06:54 AM
  4. Question about Power Supply to Switches
    By dougiefresh in forum General Hardware Discussion
    Last Post: 06-17-2005, 04:57 AM
  5. fuse splitter, switches, noisy parts express 5" lcd
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-21-2000, 11:06 AM
