Results 11 to 20 of 22
Thread: EVO X Monitor Fabrication *WORKLOG* Nexations Creations
  1. #11
    Dec 2005
    Raleigh, NC
    Very tidy build. I especially like how you angled the buttons. That's a very OEM touch.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  2. #12
    FLAC WuNgUn's Avatar
    Sep 2007
    Is that a special paint, or did you just do the 'misting' application?
  3. #13
    Dec 2005
    Raleigh, NC
    I usually put several light coats of sand-n-fill primer like that. If you use that (it's basically very thick primer) you can get the part looking really good and don't need to be an expert body/filler man.
  4. #14
    Sep 2007
    So your finished product is only primer? Looks realy good....
  5. #15
    Dec 2005
    Raleigh, NC
    I'm not sure what paint he used, but when I do it I usually get the automotive grade exterior paint. When I do interior stuff I usually spray a few coats of the exterior paint, but from a little further away than recommended. This gives a good color, but slightly textured finish that even further hides any imperfections.
  6. #16
    Dec 2005
    Raleigh, NC
    This looks like he used a satin black or even one of the rubberized paints. I'm leaning more towards the satin black spray can though.
  7. #17
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Based on his previous revelations, my bet is that it's a readily-available SEM product applied by The Wizard of OEM.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  8. #18
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Hey,
    For everyone that is wondering. I defintely use body filler. I use a couple different types to get the "walls" just right for primer. I only use primer to get a a nice smooth surface. You can't really fill defects in with primer unless they are like 220 grit sanding scratches. Basically the fab has to be 99% even before primer. Primer is just going to tell you where you need to spot putty small defects before final primer and paint.
    I spend a good amount of time in the primering phase. I usually do at least 5-6 stages of primering and sanding before it is as smooth and defect free.
    Then I will proceed with SEM Texture (not the primering style texture) SEM Texture is really authentic looking texture, although it is a bit diffucult to work with.
    After that I will go through a little process I developed in which I will apply the Satin Black paint for the final look
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
  9. #19
    May 2007
    update of it installed?
    AIM: Exus28
  10. #20
    Aug 2007
    Quote Originally Posted by treetop777 View Post
    Makes me sick! ('cause i wish i had the talent)
    You know, I thought the same thing too when I first saw his work...really ticked me off I didn't have the know how. Then it dawned on me to say "screw it, I'll send it to him to do". I've done it twice now for two separate builds and couldn't have been happier with the outcome.
    Jay
  1. Replies: 29
    Last Post: 01-29-2009, 12:55 PM
  2. Replies: 22
    Last Post: 01-02-2009, 02:06 PM
  3. Compaq Evo n160
    By brandname2007 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 10-01-2007, 11:59 AM
  4. Evo VIII owners - suggestions?
    By NegativeFX in forum General MP3Car Discussion
    Last Post: 01-05-2007, 10:31 AM
