Make a bezel from a soft material that can be worked, like foam or perhaps wood. Sand it until it matches the form you want, then make an inverse mold of it.
Alternatively, what you need access to is one of those 3D measurement machines that allows you to take measures from a reference point and translate that to measures on the face of the bezel. You might be able to rig one up using a laser level and measure the distances with a ruler but it won't be as accurate.
LinkBack URL
About LinkBacks
