Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: my new chrysler 300c xenarc monitor fab and cpu case
  1. #11
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    That's a very nice "custom cpu case" there. Could you give us more information on that, please?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  2. #12
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    I have a company that builds them for me. They are made to fit micro-atx boards. The mounting hardware inside the case is design to hold a 3.5 hdd with Hard drive shock-reducing suspension , opus 150 or the new 180psu. Custom slim clear-anodized aluminum Micro-ATX enclosure, designed for maximum cooling and air-flow.
    Dimensions: 12.0x11.2" footprint, 11.2x11.2x3.7" box. I sell these case for $149.99
  3. #13
    Oct 2005
    east coast
    here of some more pics of bezel and monitor hooked up to the carputer in my house
    I use streetdeck 2 as my frontend. It works better then the sd1.
  4. #14
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Very nice fabwork on the bezel man, looks hella tight. Where did you get that abs plastic to fill up those gaps? I'm digging the 2 usb ports on there.
    My carpc worklog
  5. #15
    Oct 2005
    east coast
    Quote Originally Posted by rgarjr View Post
    I had some laying around from a old honda headunit kit. I used to get it in sheets of 12"x12"x 1/4", 1/8" for around $5- $10 depends on the thickness. I got mine from bestkits.com (aamp, stinger) I used to have a car audio shop, I would get all my kits and plastic from them.
  6. #16
    Jan 2008
    Covina, CA
    Quote Originally Posted by customaudioman View Post
    So you pretty much filled up the large gaps by putting small pieces of abs plastics on there? Did you tack weld them in place by using a hot iron?
    My carpc worklog
  7. #17
    Oct 2005
    east coast
    yes I cut pieces of abs the size of the larger gaps. I used the hobby 3-5 sec bond glue and then spray it with activator spray that tac it instant. yu can use any type of c/a/ glue. They have ones that tac seconds and some that takes a minute. depending on what time frame your working with.
  8. #18
    Oct 2005
    east coast
    here is a link for the c/a gule and activator.
    http://h1069795.hobbyshopnow.com/pro...p?prod=EFLA208
  9. #19
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Very nice work, Love the chassis, looks like that spent some time on the CNC table!
    What power supply is that?
    Looking forward to some installed pix.
  10. #20
    Oct 2005
    east coast
    Quote Originally Posted by blk02si View Post
    the psu I use is the opus 180w psu . www.opussolutions.com
    http://www.opussolutions.com/index.php?p=product&id=56
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Replies: 11
    Last Post: 07-04-2009, 04:35 PM
  3. cpu cooler touching case
    By Touran in forum General Hardware Discussion
    Last Post: 03-07-2007, 04:35 PM
  4. cpu and case temps need more cooling?
    By michaelrj9 in forum General MP3Car Discussion
    Last Post: 06-08-2005, 09:31 PM
  5. CPU & Case Temperature
    By Sway in forum General MP3Car Discussion
    Last Post: 02-03-2004, 03:25 PM
