Results 11 to 20 of 22
Thread: Critique my dash bezel paint work...
  1. #11
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Great work, What kind of texture?
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  2. #12
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by WuNgUn View Post
    Thanks...
    Do you think it should be a flatter black?
    You can always spray two or three primer coats while sanding in between, on top of the black paint to get a flatter look. Then wet sand again with 2000 grit for a more durable final finish if texture is not needed.
    I did my black dash cover plate the same way. I find that having an ultra flat black finish in the end will make it easier to match the plastic-like dash finish by touching it up with Armor-All once the paint has fully cured.
  3. #13
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Nexson View Post
    Texture is from spray technique...
  4. #14
    Mar 2008
    nice work
  5. #15
    Sep 2007
    Here it is illuminated with the screen, VU Meters and Griffin Powermate mounted...
    (Cheap cam messed up the blue colour...it's not this pale)
    As for the ugly, filled ashtray opening, I'm having this machined from clear acrylic (back painted black)...
    The lower right rectangle is for my engine start/stop button...behind it is provisions for 2 blue LED's to light up the acrylic...
    The top left square is for a pair of USB ports...
    The green outlines are machined into the face for illumination, and the two small circles over the switch mount are status LED's...
    The REAL trick will be to locate the original HVAC controls into the glovebox...I basically have to extend the operating cables (2 pair) and the fan wiring loom to reach...
  6. #16
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Hurry up... I'm anxious to see the installed pics!
    Also, where did the VU meters come from?
    Play with it, 'til it's broke.
  7. #17
    Sep 2007
    I'm anxious to get 'er installed! lol
    The VU meters came from this PC, 5.25" bay add-on audio thing...I can't even remember who makes it (Ebay), but it was practically a perfect fit...
  8. #18
    Oct 2008
    Midlands, UK
    Nice fabrication, looking good. I like the way you have incorporated the Griffin Powermate into it, but how do you keep it in place? I'm trying to mount one in my car and nothing sticks to the silicone base! Cheers.
  9. #19
    Sep 2007
    The silicone base is a layer stuck to the bottom...
    It can be peeled off, leaving the opaque nylon, which you can simply Krazy Glue...
    Believe it or not, I used nylon toilet seat bolts from the hardware store to hold it in place thru the opening...
    And Krazy Glue works awesome on plastic to plastic bonds!
  10. #20
    Oct 2008
    Midlands, UK
    @WuNgUn
    very ingenious - I like it. I think Ill give that a try myself; thanks for the tip.
    Tim
  1. 2006 Tacoma, in dash "Tacoputer"
    By DaveWilliamsTX in forum Worklogs
    Last Post: 09-21-2007, 02:10 PM
  2. Cup Holder Scratching Bezel Paint
    By ryan-neil in forum Fabrication
    Last Post: 12-04-2006, 10:00 AM
  3. Replies: 14
    Last Post: 06-07-2004, 12:37 AM
  4. Need help with dash work, lilliput mount
    By Noble in forum General Hardware Discussion
    Last Post: 03-22-2004, 05:05 PM
  5. The dash bezel begins to take shape!
    By ddt in forum General MP3Car Discussion
    Last Post: 03-09-2003, 10:55 PM
