This is the monitor:
Hi to everyone. Starting from this post I will report to you my fabrication work fro my 1999 Jeep Grand Cherokee. I bought a ByByte bezel and a 7" LED Backlight VGA screen from Vitrolight (China). The panel is the same used on new 629 lilliput. Started to work on bezel, already done for my previous all in one double din, I had to enlarge a little bit the hole, due to the bybyte frame is a little bit higher and larger than my previous 2 Din. For the case I am using an old 2 din radio case. This is first step:
It's a Jeep thing...you wouldn't understand !--------------------------------------------
Carputer installed:
Motherboard: Industrial PC
Lanner inc. Model IAC-H672
Form Factor
Half-size, ISA
Platform
VIA Mark processor, 800MHz
VIA Mark + VT82C686B
Award 256K BIOS
Processor Built-in Cache memory
System Memory
SDRAM
512MB Max Capacity
Socket SO-DIMM x1
Storage Interface
IDE x1
SSD (CF Socket)
CompactFlash I/II x1
DOC socket x1, supports Msystem DiskonChip 2000 Flash memory
Networking
10/100 Mbps
RJ45 x1
Realtek RTL8100B, Supports PXE
Display
VIA Mark integrated S3 ProSavage 4, AGP 4X Graphics support 36 bit TFT & 2 channels (2x18-bit) LVDS LCD
8/ 16/ 32MB
VGA DB15
Audio
VIA V1612A with AC’97 2.0 audio codec
I/O 5x2 2.0mm Pin Header for Mic in, Line-in, Speaker-out
I/O Interface
FDD Box Header 2.54mm x 1
RS-232 x1, RS-232/422/485 x1
LPT Pin Header 2.0mm x 1
4 USB(v 2.0)
8-bit Digital I/O with pin-header (4 in/4 out)
115k bps, IrDA 1.0 compliant with pin-header connector
Mini-DIN PS/2
Mini-DIN PS/2
Bus interface
PCI /ISA
Hardware Monitoring
VIA VT82C686B Super I/O including H/W Monitoring function
VIA VT82C686B Super I/O with Li-battery
Watchdog timer with 256-level time-out intervals
Cooling
Heatsink / Fan
Expansion
PC/104 x1
PC/104+ x1
Environmental Parameters
0~60°C ambient operating temp.
neg 20~70°C ambient storage temp.
5~95% ambient operating humidity
Physical Dimensions
185 x 122 mm (7.28” x 4.8”)
Power
+5V, +12V
AT/ATX supports, 4pin +5V power Connector
Operating System: Windows XP Home Edition SP2.
HD: SAMSUNG HM160HC (149 GB, IDE)
Radio: Silabs USB with RDS .
TV: Stick USB DVB-T
Navigation SW: Sygic 7.71 RC11 with Europe 2009 maps
GPS: Globalsat BU-353 SiRFStarIII USB
PSU/Controller: M1-ATX
Steering Wheel: CarPC JoyCon
