Results 1 to 10 of 13
Thread: What product to use
    Aug 2007
    What product to use
    I am attempting to install my 8 inch screen in my 04 f150 dash. The bezel that came with the screen is to large on the top and bottom, and to thin on the sides by about .5 inch. This is my plan.
    Cut the top to fit very snug to the dash, use a filler to blend it in.
    Then for the sides do I want to cut some wood then use filler for the side or what should I do with the gap on both sides?
    Also to recess the screen a bit I was just gonna use like 5 play model aircraft birch about .5 inches deep then mount the bezel that came with the screen on the end of the wood? Does this sound appropriate? If any of this doesnt make sense let me know so I can try to elaborate more!
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Look through TurboCad's sticky on how to make a factory bezel.
    I think you're going to wind up dissatisfied with wood, being that there's no good way to bond it to your factory bezel. You're going to be better off using products like ABS plastic sheets, and some form of ABS glue and/or plastic epoxy, rather than wood and so much filler...
    Play with it, 'til it's broke.
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Hey There,
    Do not use filler as something to bond the wood and plastic together. Although it is good to use little wood sticks to fill in the empty spots behind the bezel, you should not use filler over them just yet. I would use a CA glue to hold them together, then I would sand that down and put the filler over that. The biggest misconception about filler is that it holds 2 parts together, it does not. Filler is purposely meant to either build up small areas or get a smooth surface for primer and then paint. If you use filler over the 2 pieces, it may looks great for a few days, but once the heat gets to it and if it is mishandled, it will crack really fast.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    What is the best filler in your opinion Neson?
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    I don't know about Nexson, but the Rage lineup of fillers (most auto paint stores carry it) are the best I've found locally. Though many people call fillers "Bondo", the Bondo brand products you can readily pick up at Home Depot and Lowes are pretty crappy... Especially after you use a quality product once.
    May 2007
    Rage's line are some of the best fillers, but Rage's line is usually lite weight fillers. For the work I do, I use rage last if I need it at all, which I usually do.
    I use Duraglass which is thicker and allows for nice build up of low areas. If you try to use Rage to build up areas, you will be there all day with layers of filler. Since Duraglass is thicker, it builds up better but leaves some pinholes which is no problem because then I use Rage Xtreme which fills them right in, which is its intended use.
    I like to put it like this...
    Use Duraglass to complete your shape and basically the look of the bezel and just use Rage to get it smooth.
    AIM: Exus28
    May 2007
    Thanks Nexson for this input!!
    Final Install
    CarPC progress: 95%
    Oct 2008
    Pa
    Just have Nexson do it for you.
    He molded a 8 inch screen into my dash kit.
    See link for pics.
    EVO X Monitor Fabrication *WORKLOG* Nexations Creations
    The quality is second to none and the price is very resonable.
    Brian-
    May 2007
    ^ Thanks Sir!
    it is always great to hear from satisfied customers!
    AIM: Exus28
    Aug 2007
    haha Ya I emailed him a while back but I have this ego issue and I want to give something like this a try. . . I think! Im not sure im still trying to encompass what all this job entails! I know my friend (who has the same truck as me) is following my idea on this and if I can do mine right, then I can do his even better!
  1. What the Mp3Car Store looks for in a Product
    By Heather in forum Product Suggestions for the Mp3Car Store
    Last Post: 10-24-2008, 11:05 AM
  2. Replies: 17
    Last Post: 12-02-2007, 02:50 PM
  3. Jobs - Mp3Car.com Retail Product Specialist
    By Fiberoptic in forum Announcements
    Last Post: 08-11-2006, 12:33 PM
  4. Route66 remove its Mac/PC product
    By MacMobile in forum MacCar
    Last Post: 04-05-2006, 08:46 AM
