Results 1 to 9 of 9
Thread: ABS sludge keeps bubbling up in heat
    Mar 2007
    Hey all i gotta quick question about working with abs sludge. I'm using abs sludge on my aftermarket dash kit to add another piece into it (putting a custom iphone dock underneath the stereo). Anyways, I spend a good deal of time filling in all the little bubbles and crap and making it nice and smooth, let it set for a few days and then began painting. After i get it looking just about perfect, i put it into my car and within hours the abs has bubbled up and it looks like hell. Is there something that can be done to prevent this??
    thanks for any tips
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Sure!
    Don't use it!
    Most likely the ABS plastic is expanding with the heat and creating those bubbles in the paint as it releases air.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Mar 2007
    ok... well what would you recommend using in place of it? From everything I read, it seemed like bonding abs with abs was the best way to go because it prevented any cracking and made a permanent bond.
    May 2007
    CA Glue, most defintely
    AIM: Exus28
    Mar 2007
    cool... i've got plenty of that at work so i'll give that a shot. But what would i use as a "body filler" to make the surface nice and even? I'll post pics later on to make this a lot easier to explain...
    May 2007
    Yea, The body filler goes on after the CA Glue has been sanded down to be somewhat even. The filler fills in little pits and dibs.
    AIM: Exus28
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Are you priming the surface before painting? I'd bet that it's not that the plastic itself is bubbling, but it's the paint that's bubbling on the surface of the ABS plastic.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    Apr 2007
    Quote Originally Posted by Pepe View Post
    thats what i was thinkin too. try some kind of plastic bumper repair or some automix/duramix/fusor etc. that stuff will hoild damn near any plastic. make sure to get the right kind for your needs.
    Oct 2007
    Bako, California
    I just used some regular abs glue on my bezel and it works fine. the stuff you get at home depot or lowe's. Of cours like they have all said you just use it to get the initial structure of your bezel and use a little body filler to give it that clean look after sanding it down.
  1. Problems with the ABS sludge method...
    By zapro in forum Fabrication
    Last Post: 04-25-2008, 02:31 PM
  2. ABS sludge
    By rgarjr in forum Fabrication
    Last Post: 03-11-2008, 12:18 AM
  3. Clarification: PC ABS
    By fnkelton in forum Fabrication
    Last Post: 07-06-2007, 07:12 AM
  4. My try at ABS sludging a xenarc
    By evandude in forum Fabrication
    Last Post: 08-09-2006, 01:20 AM
  5. Salvaging my ABS sludge install with fiberglass?
    Last Post: 02-11-2006, 06:22 PM
