Results 11 to 20 of 23
Thread: Help me fab my dash, Nexson come plz
  1. #11
    Aug 2007
    I also have a 7 minute plastic epoxy from loctite!
  2. #12
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Sand the areas where the bezelw ill meet the panel. Really rough them up. I would use your epoxy first to join the 2 pieces together. From here just as you said, duraglass for 75% of the structure and finish it off with rage.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  3. #13
    Aug 2007
    should i be getting different types of sandpaper (in terms of grit) im gonna start with 30 to rough up the edges
  4. #14
    May 2007
    i would shape ur duraglass with 40
    as it shapes better then move to 60-80, then sand the rage with 80-120-220, then work your primer through 220-320-400
    AIM: Exus28
  5. #15
    Aug 2007
    Here are a few pictures of my dash I worked on last night. Im gonna do more tonight. I have a problem making the corners look even. I only put my first coat of the duraglas on though.
  6. #16
    May 2007
    Looking good.
    The best advice (which I had not mentioned yet) is to stay away from the inner portions of the bezel. They will eat you alive in frustration trying to get them straight again. I usually tape off the inner edges of the bezel so I will not mess with them, no body filler is needed in that area anyways
    AIM: Exus28
  7. #17
    Aug 2007
    Ok so i finished it today. The bottom left corner is slightly misshaped but im still happy with it! Nexson Thank you so so much, I really am immensely grateful for your spoonfeeding me like you did!
    Here are the finishing pictures
  8. #18
    May 2007
    As far as I am concerned, that came out great!
    You got to be proud of yourself that you did it yourself and saved $
    Job well done!
    AIM: Exus28
  9. #19
    Aug 2007
    Thanks a bunch for real!
    I read your other thread that has all the worklogs and what not, and how your desire is to become a teacher! This is a prime example of your capability and how helpful you really are!
    NO HOMO though!
  10. #20
    May 2007
    Quote Originally Posted by TexasAggie View Post
    NO HOMO though!
    hehe No Problem.
    Fully Understood!
    I should be there in less then a year now, but small fabrication work will always be a part of my life.
    I know it was hard for me to figure out in the beginning, so at the very least, I want to be as support to others.
    AIM: Exus28
  1. Mounting lcd screen OVER oem dash
    By chaos7692 in forum Fabrication
    Last Post: 02-02-2008, 06:33 PM
  2. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 07:47 PM
  3. Made fiberglass dash but looks like crap! PLZ HELP!
    By XxAndyxX in forum Fabrication
    Last Post: 08-24-2006, 12:50 PM
  4. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
  5. New Dash Bezel Fab Problem
    By legend5761 in forum Fabrication
    Last Post: 11-12-2004, 01:32 PM
