Any reason why you can't do the 'glass work while the
head unit is installed?
One thing to consider, if you stick with the current method of affixing the front panel to the console, and you stain it, you will see the screws holding it together. Aside from wrapping every individual panel in fabric (which will ruin the fit of all your pieces, causing them to need trimming) you're going to have to find some way to work from the backside of the console to mount everything.
If it's really not an option to do the 'glass work with the head unit in, you should be able to find a way to make this work. Your major obstacle being that you must try to make the head unit's bracket mountable from the backside of the console. I've been wracking my brain for a way to mount it, with no success, but I'll keep thinking on it.
And now I've got a question for you
What wood did you use to construct the console? Is it relatively firm? It seems, in the pictures, to be quite thin, and possibly prone to breaking. So I'm curious as to why you went with such thin wood?
