+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Cutting rectangles in plastic, but small ones!
    Vendor - Qube colin's Avatar
    Dec 2006
    Ive read a few threads about cutting in plastic and its always blah blah about drilling and using a jigsaw.
    I want to put a set of buttons beside my screen sort of like this:
    I want the buttons to be lit with LEDs so I think these would work best:
    Except, how do I cut those small little rectangle openings into my bezel (the picture is someone else's bezel with a screen in it):
    Dec 2006
    Or another example, how do you cut the rectangles for the USB ports in this picture:
    FLAC djmickyg's Avatar
    Feb 2004
    Melbourne, Australia
    drill a small hole then open it up with a square needle file
    Oct 2007
    Switzerland
    1. drill a hole and adjust the shape with a file
    2. precision punch like these: http://www.precisionpunch.com/webpage.cfm?page_id=7
    Mar 2006
    Colorado, but Canadian!
    Better yet, use a laser cutter. Most people that have them wont mind doing it. Some will make you pay a few bucks, but it is exact and fast. And it is a laser so the overall cool/geek factor goes sky-high.
    On a side note, where did you source those button thingamagiggs that go over the pushbutton knob?
    1.9in x 2.9in -- 47mm x 73mm
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by colin View Post
    From the clean cutting and the USB logo in the middle, that one looks like a laser cut. That's the best system -- if you have access to a laser cutter.
    If you don't have that access, some very careful -- very, very careful -- cutting with a simple X-Acto knife and a steel straightedge can get you there. If you have a template, it's easier, but you really can cut straight lines in plastic. Cut a fine, shallow line to mark the shape, and then deepen the cuts slowly and gently.
    This is slow, precise work, and it takes attention to detail. Practice on scrap, and then go for it. The keys are to go slowly, keep all your cuts gentle, and use good, sharp blades. Cut less than you want each stroke. You can do it.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Dec 2006
    Quote Originally Posted by 2k1Toaster View Post
    I was searching for rotary encoders and I went to a place that I was sure would have them (they didnt): SparkFun. If you haven't heard of them, theyre like a general hobby electronics place with a very easy to use catalog and very interesting front page posts. The product is called the IceCube Light Pipe Switch
    Quote Originally Posted by rdholtz View Post
    That's the process Ive used all my life, except it does not ever produce good results when I do it. It takes hundreds of swipes to go through a decent sized piece of plastic, that's why I'm inquiring about this
    Guess I just have to buy really, really small files or find a local laser cutter.
    FLAC WuNgUn's Avatar
    Sep 2007
    CNC mill...I've had intricate acrylic machined perfectly for my needs. Not the cheapest solution, but you draft it up in CAD and you get exactly what you asked for.
    Dec 2006
    Cheap is the top priority. Its like 6 or 7 holes, dont wanna spend too much money on it.
    May 2008
    how bout a dremel tool?
+ Reply to Thread
  1. drilling through plastic
    By jusatry in forum Fabrication
    Last Post: 01-14-2007, 12:22 PM
  2. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 12:51 PM
  3. looking for a 5.1 channel SMALL amplifier
    By RogerWilco in forum General Hardware Discussion
    Last Post: 09-21-2004, 04:19 PM
  4. best plastic adhesive/filler?
    By sohr in forum Fabrication
    Last Post: 06-22-2004, 02:28 PM
  5. Where to find small plastic enclosure?
    By Gutter in forum Off Topic
    Last Post: 03-18-2004, 02:26 AM
