The woodgrain is probably either a vinyl overlay or something cast right into the plastic. You might be able to get vinyl that would somewhat match and then lay it over your finished bezel, but more likely you are better off just painting. Gloss paint is more unforgiving of imperfections than flat is. I used bondo for shaping my bezel, you could try using that or something else and plenty of sanding to try and transition the curved bezel to the straight LCD frame.
LinkBack URL
About LinkBacks
