Results 1 to 10 of 20
Thread: Slot-load ANY screen without voiding warranty
    Dec 2008
    i mentioned in another thread about roller tracks for monitors. found the tracks, now i found a way to have my screen slot-load in my truck without even modifying the screen itself in any way.
    pics are crappy, i cant find my canon... but the amateur job i did is much worse the then quality of pics, so dont laugh. rollers came from rockler shameless plug because the rollers are top quality for a fair price.
    the hinge bar is actually a piece of 3/8 brake line. very tough. the holes in the rollers were the same size as the od of the brake line, so i made the line a little longer then needed and pinched off the ends. won't go anywhere, it still swivels, and best part is how easy it was to do.
    i have no metal fab tools (obviously) just a drill, rivets, and bandsaw.
    as you can see, the screen fits perfectly, and it works just as good as anything could-
    this is screen fully in. notice the bars sticking out the back while closed. i made sure there IS enough room in my dash to accommodate.
    when the screen is pulled out, the rollers have a 'stick' point at the end, where it sort of locks into place. this will keep the screen from sliding back and forth when its out.
    and you can see here how it will fold down. i dont have the hingebar mounted to the screen yet, but i will simply make metal bands that will wrap around the ends of the screen and attach to that bar (the bar swivels freely).
    the only thing i have to figure out is how to make the screen stop at the angle i want when i swing it down. but that should be taken care of will small tabs on the hingepoints.
    that, and actually mount this thing under my radio- but that should be easy. this was definitely the hard part, and it only took me two hours with like i said, no skills at all.
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    did you plan to get it motorized ?
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Jan 2008
    looks great!
    Dec 2008
    Quote Originally Posted by VmtSquad View Post
    no. this is a 'kiss' project. above all else, it must work every time. this is all going in a personal/construction work truck, and my goal is to enjoy the truck-pc more then hate it... so im trying to do everything as maitence-free as possible. i would have just permanently mounted the display and used a trick cover, but i wanted to keep my pioneer radio for am radio and backup in case the computer is ever down. the sound output for the computer will just go into the aux in on the stereo.
    motorized would be possible i guess, but very unnecessary.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    This is very nicely conceived. How do you plan to handle the cables?
    Instead of some loops around the monitor case, many of them have mounting points on the back. A panel of heavier material could attach to those points and connect to your pivot bar. It might even extend beyond the top of the monitor and provide a handle you could use to pull it in and out of the dash.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Dec 2008
    you know, i had just thought of that late last night before bed. if there is enough clearance on the bottom, and i think there is, it would be an easy way to go.
    i was also thinking about using foam around the bar where the screen mounts to (make the bar solid so it doesnt spin). if i can secure a loop tight enough around the bar and foam, it should make a nice fully-adjustable swivel point, for the folding up and down motion. the screen itself doesnt weigh anything, but the swivel needs to be tight enough for when i touch the screen it doesnt flop back. there are still a thousand ways to do this swivel, so im not set on it yet by any means
    also, i'll take a pic of how the wires fit. this is one of those lucky moments i tend to get here and there, where something just works perfectly without trying. on the lilliputs, the wires stick out the side, and in this contraption they fit exactly underneath the right rail as it slides in. the fit is picture perfect, as ill show you
    Low Bitrate eigenVector's Avatar
    Apr 2009
    Awesome job on this! Looks great!
    Dec 2008
    as you can see, the wires stick out to the sides but they still fit nice
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I am going to be honest here. Great idea but I think it could use a little more touching up
    New Age Garmin - Skin for RR
    Dec 2008
    mechanically, its very sound. i already admitted it appears to look like s&^%t since this goes all inside the dash, there's no reason for it to look nice anyway. surely though, anyone with the most basic metal fab shop could make something much more appealing to the eyes... it just wouldn't work any different so its a non-issue for me.
  1. FS: M10000, Morex 3688, 40GB 2.5", SLOT Load dvd/cdrw, 512mb ram
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 07-13-2006, 11:53 AM
  2. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  3. Slim, slot load, DVD drive, where to get one??
    By JonEQuest in forum General Hardware Discussion
    Last Post: 06-23-2005, 02:58 PM
  4. F/S: BRAND NEW 7" VGA TOUCHSCREEN AND SLOT LOAD DUAL FORMAT DVD BURNER
    By jackjohnson24 in forum Classified Archive
    Last Post: 11-26-2004, 01:39 PM
  5. FS: 7" Lilliput w/ TS, iMac slim slot load DVD
    By sohr in forum Classified Archive
    Last Post: 08-15-2004, 11:35 PM
