Results 1 to 9 of 9
Thread: How to cut a USB rectangle in a dashboard
    Nov 2008
    I have a couple of these: http://www.datapro.net/products/usb-...e-a-cable.html
    And i want to fit them to (cut a long story short) a dashboard piece thats plastic and screw into it so the only thing visible is the female USB socket and the two attaching screws.
    If i invest in a dremmel router attachment will that cut the perfect rectangle?
    It's going to be on show so I don't want the rectangle holes to look gash. Any other options?
    I don't mind buying a different USB socket if it's going to be easier.
    Cheers
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    I made a metal plate for my dash that has 2 USB ports on it, using cables very much like in your picture, but taken from a PCI slot card faceplate.
    I used the PCI faceplate as a template and drew the rectangle holes, then used a dremel tool to make the openings. The first one I did looked like crap but I learned how to slow down and move more carefully. The second one came out pretty good, although not perfect, but good enough for me. I used a flat file to square out the corners since they were rounded from the dremel metal cutting bit.
    Good luck!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by MichaelPlace View Post
    I found these to be a lot more forgiving; you can make the hole undersized then file down untill the usb (female) end can wedge-in.
    http://www.usbgear.com/USBG-AAE2C.html
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It almost always looks better when you work from the back side. Well, you can mess up more.
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    You have to be VERY careful with the Dremel, or you can overrun your lines. It's best to practice in some scrap similar to the dash.
    Another approach that's less likely to produce a mistake (and the resulting expletives) is to simply drill two (or three) properly placed holes and file out the space between them. The drill diameter should be the the same as the width of the hole you want. Using a centerpunch on the dash to make dimples that mark the hole locations so the drill bit doesn't wander. You may have to hold a backer board in the area where you use the centerpunch.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Be very carefull with doing this with a dremmel... You need skills and steady hands...
    If you have not used a dremmel before... This is not the first thing to try it on... practice ALOT before you plan to do it on the actual panel.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Cheers
    OMFG, I'm glad I came across this post, I have been looking for something like this. My setup has 4 USB ports and 6 additional USB each for the independent systems. I have 6 extensions going to my center console but wasn't sure if they made the cable you pointed out. Now I can hide the 4-port hub also..... Thanx a bunch!
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    Vendor - Qube colin's Avatar
    Dec 2006
    For the record, HiJackZX1, there are much cheaper cables available at FrontX. Someone else posted the website a while back, and I ordered some USB extension cables from them for my dash. The look the exact same, are very good quality, and cheaper.
    Jul 2007
    Miami
    Quote Originally Posted by colin View Post
    Yea I saw that. FrontX has theirs for 7.00 a piece. What I needed was the name of this cable, which I didnt know till I found this post.
    4x 10inch Tablet
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. Ultimate USB, Firewire, External Soundcard List
    By durwood in forum Car Audio FAQ
    Last Post: 12-30-2009, 05:15 PM
  3. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 02:30 PM
  4. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 11:49 AM
  5. False floor
    By i3igmind in forum Fabrication
    Last Post: 02-04-2006, 10:28 PM
