Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 134
Like Tree13Likes
Thread: '08 Dodge Dakota, Console Fab, Install Pix
  1. #121
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Finally upgraded my battery to something good :-) Northstar ultra high performance AGM battery. This thing is sweet 930 CCA! The factory was only 700 CCA. Not shown in the picture but done today was upgrading the ground strap and main power feed to quality 4 guage wire. This made a big difference in the OEM and aftermarket electrical systems. No more dimming of lights when high load circuits are in use like full heater or firing HIDs. Starter motor sounds like a jet turbine now. All in all im happy about the upgrade. PC is still running great!Name:  20140327_100928.jpg
  2. #122
    Oct 2010
    Greece
    Man nice work you got there. Congratulations for ur new birth too. I wish you the best for all ur family. If you dont mind i have a question . I saw that in ur first setup you had installed a cf to ide adapter. Were you happy with it . Was it running faster than a hdd ( 5400 or even 7200 ) . I want to buy one and test it ( not in the car but it my daughter's pc. Did you had it for primary and windows installation or just files ?
    I am wishing you the best for ur new baby family and ur nice car.
  3. #123
    Jul 2005
    Motorcity
    Blog Entries
    1
    Yes definitely faster than a HHD, but I was using that back before the widespread availability of SSD's. I would suggest using a modern SSD over the CF > IDE adaptor.
  4. #124
    Oct 2010
    Greece
    Quote Originally Posted by blk02si View Post
    No more ssd for oyr pc now. I just plugged the one in the car cause i was afraid of vibration. i have a spare cf (4 GB) so i was thinking an adapter which is cheap to add some virtual memory to my kid's ( p4 ) pc.
    Thanks for the feedback man.
    Vw Sharan 2007 1.9tdi || Exide 100Ah
    Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
    Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
    Powered by M2 atx
  5. #125
    Jul 2005
    Motorcity
    Blog Entries
    1
    Update, My Directed HD tuner finally died :-( It's been acting strange, cutting out and sometimes not turning on for about a month. Finally it just quit working.
    Not a bad run though I've had it for 7 years. Picked up a new module, plugged it in, and was up and running again in about 20 minutes.
    Updated to the newest Riderunner version, finally without the nag screen and it's working absolutely perfect. Big thanks to mitchjs for his continuing efforts.
    Also put some new suspension on at all 4 corners. Rides like new again. Put some monroe load sensing shocks on the back with the extra coilover. New suspension lifted it about an inch :-)
    In other news I started a projector retrofit for the headlights. Its been slow going but I keep chipping away at that project day by day.
    Last but not least my new boy has been taking most of my free time, he is an amazing little guy. I can already tell he is going to be following in my footsteps with the technical stuff ;-)
  6. #126
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well a sad day.. PC stopped booting :-( pulled it from the truck yesterday to find a lot of corrosion on my m2atx and after initial testing , looks like a dead mobo. Hopefully the ssd is ok! I was just thinking about how creating an image would be a good idea lol. over 2 years since installing the gigabyte mobo , so not too bad of a run. I ordered a new m2 atx, but could not find a new mobo of the same model. I did find a lot of used mobos of the same model number on ebay guaranteed to work for $20 each so i bought 2 :-) Hopefully these parts will get me back up and running! ill keep ya guys updated. Took some pix of the old m2 that is 8 years old now, not sure where or how the corrosion started.
  7. #127
    Sep 2009
    bummer about the mobo, nice looking retrofit and kid!
  8. #128
    Jul 2005
    Motorcity
    Blog Entries
    1
    Good news! my new mobo's arrived today and the first one I pulled from the box booted right up! I love tinyXP and these embedded atom boards. This is the third board ive booted this ssd from with no issues or bluescreens. Guess all that cpuid crap is stripped out! Posted this from the new mobo carpc first time on the internet in years! most log out now.. xp with mozilla 3.0 , wont lat long on the net. Went on to post this and update VLC. Also used linux to clone the SSD to a backup drive :-)
  9. #129
    Jul 2005
    Motorcity
    Blog Entries
    1
    Got my new m2-atx, and put everything back together. Took some pix along the way that are on my phone. Ill try to get them uploaded. System pretty much booted right back where it was. Despite moving the USB connectors around everything still worked and retained the same port assignment!
  10. #130
    Sep 2013
    Sydney Australia
    Any thing else to report? How did the Samsung screen turn out?
  1. Lilliput screen on Ubuntu
    By yam125 in forum Linux
    Last Post: 06-13-2011, 11:19 AM
  2. Replies: 0
    Last Post: 11-03-2007, 04:33 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  5. New Console Fab in 2002 Dodge Caravan
    By SillyClown in forum Fabrication
    Last Post: 06-09-2005, 07:48 AM
