Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 107
Thread: '08 Dodge Dakota, Console Fab, Install Pix
  1. #41
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Thats great! I knew you would love the setup without the HU. Its like having a middle man, simply not needed. Im glad its all worked out.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  2. #42
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I need a fusion brain now, I have the volume knob but I want to control relays and use my steering wheel buttons to do something. Stay tuned.
  3. #43
    Dec 2006
    I'd like to see what it would take to reverse engineer the CHTO-03 interface? Instead of spending the $100 or so for it. I'm sure for the Dodge and Chrysler owners, with the High Speed Interior CAN Bus this would make installing a carputer to the factory amp a breeze. A DIY project and not even go the route of the CANUSB. Any thoughts?
  4. #44
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well I opened up the module and there is a lot going on in there, there's also a gain adjustment that I set so the system level out matches the level into the amp. I am still really impressed with the sound, no noise at all using this module. It's expensive but I would have to say it's worth it for how 'hassle free' the install was. I just tied the red wire to the blue/white on the CHTO-03 and now the amp turns on with the ignition. I may put a switch in there too so I can turn off the amp manually if I choose.
    So on another note the first problem has surfaced, the wifi adaptor seems to be confusing the TPMS sensors, it's strange, only once and awhile the light will go off prompting me to check pressure. I do and it fine. After more research it appesrs the TPMS sensors also broadcast wireless into the truck. I disable the wifi and bam no more TPMS idiot light. So this is one side effect I did notice running wifi on the system inside a new chrysler.
    Also upgraded my main PC power feed to fused 8 gauge direct from the battery. System has been running well these past couple weeks.
  5. #45
    Jul 2007
    Miami
    Quote Originally Posted by blk02si View Post
    I am so glad you brought up this issue. A number of people have been having issues with TPMS. I kind of stated that it was possibly something interfering. Originally when these TPMS units and sensors were designed, they didn't take into effect that cars would have Wi-Fi, Air Cards, BT, GPS, and RF devices. On my install, my GPS was constantly jumping from street to street. One day I decided to unplug the Wifi adapter and all issues went away. If you can, get a USB extension and either position the WiFi dongle (if it is USB) either at the very very front of the car, or the very very back. Since the BU-353 is magnetic, I installed it to the very back of the car, and then a Wireless-N dongle at the very front. So far no more issues. I have not tested with the TPMS though, which is smack in the middle of the car.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  6. #46
    Dec 2006
    I'm not aware if there would be a work-around for the wi-fi adapter, but I can tell you the TPMS sensors and WCM work at a frequency of 315MHz on the Dakota.
  7. #47
    Jul 2005
    Motorcity
    Blog Entries
    1
    going to be detailing out the dakota tomorrow, doing the mobil1 oil change and working on the electronics some more. Hopefully I can find my camera and get some pics of the install. (just moved to a new house, still unpacking)
  8. #48
    Newbie optimus124's Avatar
    May 2007
    SC
    Nice
    Glad to know you can get the CanBus to do something. Any update on the steering wheel buttons doing anything. I drive an 06 Charger. I haven't plunged on this yet for that fact
  9. #49
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've been somewhat stalled on the project as it is working great and I am tackling a remodel job on the house I bought. I did manage to attach the new dedicated 8 gauge to the PC complete with two switches, one for the amp and one for the PC power disconnect. I am charging up my camera now so the pix will not be much longer!
    As for the steering wheel buttons, my next purchase from the mp3car store is going to be a fusion brain to interface with the wheel controls.
  10. #50
    Jul 2005
    Motorcity
    Blog Entries
    1
    Here's what I'm lookin at:
  1. Lilliput screen on Ubuntu
    By yam125 in forum Linux
    Last Post: 06-13-2011, 11:19 AM
  2. Replies: 0
    Last Post: 11-03-2007, 04:33 PM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  5. New Console Fab in 2002 Dodge Caravan
    By SillyClown in forum Fabrication
    Last Post: 06-09-2005, 07:48 AM
