Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Finish keeps getting ruined by dust, any tips? Also weird primer cracks...
  1. #11
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I used the wet floor technique when I painted my motorcycle fairings. Works great. I just hung the parts with mechanics wire from my lift in my garage at work and washed the floor down and painted. The only downside is that it creates a bit of humidity. But for the type of paint you're using it wont effect it.
  2. #12
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    Dust is usually un-avoidable, which is why we can buff them out in the clear coat. You should be using SEM products because they dry within second so no dust forums.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
  3. #13
    May 2007
    Oh, and as for the primer, it should go on smooth, either you are putting it on way to thick or the surface underneath is wet.
    AIM: Exus28
  4. #14
    Low Bitrate jake789's Avatar
    Apr 2009
    Quote Originally Posted by Nexson View Post
    Can anyone point me to the correct clear coat that I should order?
    http://www.tcpglobal.com/autobodydepot/aeroclear.aspx
    Also what do you guys mean by buffing, would that be with a dremel/buffing wheel or with rubbing compound.
    I'm thinking maybe I should do gloss black instead of satin black. Any comments/suggestions??
    Sorry if this is common knowledge, I did search google and I guess I just don't know the proper terms to search for because I'm not really finding anything....
