Junkyard to get a spare? :|
I started to add my PC selection and Power button to each arm rest. The first one was of course messy because it was the so called prototype. I made the top holes alittle to big and made a hole I didnt need. What can I use to make the holes smaller? Also what should I use to close the holes up that I dont need?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
LMAO..... Ive already drilled into the originals. Rdholtz suggested I go to a Auto Paint Supply store and pick up plastic filler. I think what I will do is get a metal rod thats the same thickness and then put grease on it then fill in around it. That way the plastic filler won't stick to the rod. I hope it will work!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
Could you put like some black grommet type thing in the hole to just fill the space? Or maybe a washer under it and paint it black? Might not look great, but could make it look better.
With that type of texture it might be hard to cover up that hole.. Maybe get bigger buttons for the 2 that you use and find an excuse to have a 3rd button to control something?
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
