Page 39 of 45 FirstFirst ... 2930313233343536373839404142434445 LastLast
Results 381 to 390 of 448
Thread: E46 - CarPC Work Log
  1. #381
    Nov 2006
    I am having similar issues with placement. I don't want to put it in the boot because all the wires for screen etc have to come back to the front, I am thinking of putting it under the drivers seat.
    I don't think I Have the same hole as you in the front?
  2. #382
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Under the drivers seat have been in my mind as well, but I'm not sure if its space enough. (I have the seat tilted all the way down).
    I thought all E46 had this space?
    Found this of a (supercharged) M3: http://www.muslimrahman.com/wp-conte...ngine-View.jpg
    Looks like the same free space. (Up to the left of the picture).
    Another pic, from a 323Ci .. This one is also supercharged thought.
    http://www.beastpower.com/products/ess/ES-SC-115-15.jpg
  3. #383
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    The models that for weight distribution reasons has the battery in the boot has this void. Lighter 4 cyl versions do not.
    I was thinking about putting a second battery there, but having the PC there seems like a great idee for availability! There are holes for bolts for monting a box to keep the dirt and water out. And genomföringar for cables!
    How are you proceeding, Kraimer? I was surpriced to here that the Lilliput did not have "ignition" nor "rearview camera" wires. And since your panel is transflektive I am also interested in how dark the screen is when LED backlight is off. Will you still see the welcome screen? Let me know.
  4. #384
    Nov 2006
    Mine is a 323, and it has the battery in the back, so maybe it does? I just haven't looked haha.
    Would be much handier than putting it under the seat - but still, would you need to make an airtight box to stop water etc getting in? Is there easy access for cables to get through from the dash?
  5. #385
    Sep 2005
    Stockholm, Sweden
    Do you never open the hood, grey :-)
    At the lower part of the picture you can see a big rubber octopus. I think you can use that for cables.
    I think "a lid" would be sufficient for water, but you would maybe want some rubber for vibrations too.
  6. #386
    Nov 2006
    I hardly ever open the hood haha, and when I do, I don't generally look around much :/
    I have been thinking for a while about where to put the carPC actually - under the seat wasn't that appealing to me.. but this is looking good!
  7. #387
    Nov 2006
    Can you tap into that power source there too? and is there a good earthing point there already?
  8. #388
    Sep 2005
    Stockholm, Sweden
    Definitely! This idee seems better and better! To bad poweramps will not fit... (?)
  9. #389
    Nov 2006
    My amps are both tucked away nicely where the CD changer in the boot was - so not a problem for me
    I just have to go have a look at this hole in the morning and see if it actually exists in my car.. and then see how I am going to mount my CarPC into it :/
  10. #390
    Mar 2009
    The large nut like thingy is ground, and as Bes said. The "rubber squid" is there for pulling cables through the firewall. PERFECT...
    The two powercables that already run there, I'm a bit unsertaint about, but I do think they are for ECU.
    Regarding Amps...
    I do believe that the Alpine PDX 2-channels would fit there. But as long as you go above 2-channels, they would be to large to fit.
    I have not messured amps and "cargospace", but perhaps I should?
  1. E46 CarPC with Original HU
    By samourr in forum General Hardware Discussion
    Last Post: 08-11-2011, 07:40 PM
  2. mk 5 ford fiesta work log *56k warning*
    By Tone in forum Worklogs
    Last Post: 07-28-2007, 01:21 PM
  3. E46 steering wheel controls to carpc...
    By JTfromSTL in forum Input Devices
    Last Post: 08-29-2006, 01:04 PM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
