Page 4 of 45 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 448
Thread: E46 - CarPC Work Log
  1. #31
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Nice rapid prototyping, bezel looks good. Too bad the texture was not more consistent, I like the way it looks!
  2. #32
    Dec 2006
    BK, NY
    Quote Originally Posted by blk02si View Post
    Thanks! I am not too worried about the texture. I had an option of placing the model differently in the printer, but that brought the price up; I decided to go this route because I figured filling in those imperfections wouldn't be a big deal at all.
  3. #33
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    That rapid prototype is amazingly good. I have to look around and see where I can get that done. What a huge leap forward!
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #34
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    I'm awestruck!!!
    Nice bezzel!
    As you say, making this bezzel smooth and soft realy isn't that hard. Since it's allready rugged, you can start to fill it with mold stright away, rubbit, and put some thin layers of putty on top.
  5. #35
    Dec 2006
    BK, NY
    Quote Originally Posted by rdholtz
    Thanks! I'll put up fitted pictures in a little. You can see how perfect the fitment came out. I highly recommend these guys - http://www.printo3d.com/ Bradley knows what he's doing!
    Quote Originally Posted by Crinos View Post
    I'm awestruck!!!
    Nice bezzel!
    Thank you! Well I don't really want to make it soft but I know what you mean That was the idea regarding the finishing - since its already rugged, whatever product I decide to go with will adhere nicely.
  6. #36
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    WOW, Looks great! Now to the easy part! Knock down alot of that texture first, before you fill it, then smooth thin layers on it and sand it down from 80-220. You know the proceedure. Repaint with SEM Texture and Satin Black!! =)
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: Exus28@aol.com
  7. #37
    Dec 2006
    BK, NY
    Quote Originally Posted by Nexson View Post
    Thanks a lot Brian!! A WOW from you really means a lot!!!! I was thinking of doing just that - sanding down the texture, but to leave enough for Bondo (or similar) to adhere and then fill in.
    Here are some fitment pictures:
    Note how the screen fills the entire frame
    AHHH YEEEEEEEE
  8. #38
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Stockholm, Sweden
    Delay :-)
    Great job!
    1) When you did the model; could you select the ruffness to be "upto" size or "at least upto" size?
    2) Are the two flexstrips on the pics "touch" and strip to a mainboard?
    3) Will you not use the OEM frame? How will you keep it all together? Where will you put the mainboard?
    About the pcb
    I have now bought a N52 from Hiinfo (6,5" panel at 550USD) that I will integrate into my 2'nd BM. That unit has an 7 lead (8 really, but one is cut away) flexcable 1mm div to connect its buttons.
    What I want to do (that will delay me somewhat more) is to connect that lead to my pcb and simulate button presses. As these button boards very often work the same way* (and because I can see that you have not made room for the lilliput buttons) I wonder if you have a flexcable like that? If so I can fit a connector for it, and then you will be able to control the buttons from your pc. Spec please.
    *) using a resistor ladder
    Edit->
    Sorry, now I see the lilliput buttons in that bottom part!
  9. #39
    May 2007
    You dont even really need bondo. Just use this stuff called spot putty. It takes a bit longer to dry, but it sands easy and is easy to apply (with finger). You should sand all the lines off so it is somewhat even, then filler, prime wetsand paint.
    AIM: Exus28
  10. #40
    Jul 2009
    I actually drew up the whole thing, including the housing. Took only couple of hours. On those machines its hard to select the finish. Since it has to put a specific amount of the ABS plastic down. In many cases its better to let it do it rougher rather that finer. Since if its rougher it is stronger. In any case, rougher in this case is better since the putty can stick better to it. Also the face plate looks awesome in person, even like this. Cant wait till its 100% done.
    The thing actually meant to have Pico-ITX put inside the box behind the LCD, but kraimer has already another PC.
    The dude that drew up the thing. and finally registered on this forum.
  1. E46 CarPC with Original HU
    By samourr in forum General Hardware Discussion
    Last Post: 08-11-2011, 08:40 PM
  2. mk 5 ford fiesta work log *56k warning*
    By Tone in forum Worklogs
    Last Post: 07-28-2007, 02:21 PM
  3. E46 steering wheel controls to carpc...
    By JTfromSTL in forum Input Devices
    Last Post: 08-29-2006, 02:04 PM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
