Page 40 of 45 FirstFirst ... 30313233343536373839404142434445 LastLast
Results 391 to 400 of 448
Thread: E46 - CarPC Work Log
  1. #391
    Nov 2006
    Mine isn't empty!
    I just went and checked and it has some stuff in there - on the top it has a cap saying "brake fluid"
    So I guess I have to put the CarPC under the seat :/
  2. #392
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    No space reserved under the hood for a battery??!! Very strange indeed...
  3. #393
    Nov 2006
    Well it has the same space there - I can see the red battery cable in there - it just has a few other things in it - I assume you guys have a different place to put your brake fluid?
  4. #394
    Nov 2006
    Anybody know any other secret spots to fit a CarPC? haha
  5. #395
    Dec 2006
    BK, NY
    Been quiet lately..sorry guys. That spot in the engine bay was used for ABS hardware in older models. I thought of using that space as well for placing the PC, but I keep a bottle of oil and a rag in that spot; the rag gets soaking wet during rainy days...
    B-O, Lilliput does have the "rearview camera" in, I'm just not using them since I don't have one yet.
    If you guys remember, I placed mine under the passenger seat mounting in the BMW's optional First Aid kit box:
    little blue bag is NOT mine
    This location, to me, seems ideal as it was close enough to the screen (no need to extend the VGA cable) and close enough to the trunk (you guys call it the boot) for my amp and such. Also because this box was designed to be mounted onto the seat, it is not at all affected by the seat adjustments.
  6. #396
    Sep 2005
    You have a pink one ;-)
    With "rearview in" lacking I mean the control signal. It does have the composite input, but it is switched in automatically when signal is present. Not by control signal on separate lead.
    I think separate lead is better as the camera can be warmed up in advance.
  7. #397
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    My first aid box is... well filled with first aid stuff. Do not think it will fit under my seat though.
    At first my thoughts where to mount the PC where my spare tire is in the trunk, then the amps on top of that, and then four small subs for in the "floor" of the trunk.
    Now I will try to hide the subs where the original sub and navi unit should be, PC under the hood, and still mount the four subs in the compartment under the "trunk floor". Quite spaceious... (See attachment).
    My brake fluids is just ahead of the servo fluid. Never seen that the brake fluid have had a resovoir on the right side of the car. (on left wheeled ones).
    Regarding the "cargo hold" under the hood. I've allso been using this for some soft cloth, polish and so on. Will try to build a metal box to mount there. Going to take a round downtown to see if any companies can make me a 3D scan, so I can work with a revers CAD model. If not, it first will be a paper model, then metal
  8. #398
    Sep 2005
    My spare tire is removed from below....! Aren't our cars all E46's???
  9. #399
    Mar 2009
    Mine is an E46 facelift. (The facelift models came from mid 2002 i think it was).
    But as I know it, all E46 besides the compact have the spare on the inside.
    My E36 Compact had the spare on the outside and dropped down like yours. Same did my Z3. (Basically a E36 the Z3. I think the proper designator where E36/7 or something. Can't rembember wich where wich. Think roadster where 7 and Coupe where 8).
  10. #400
    Nov 2006
    Mine is a pre-facelift and my spare is on the inside too.
    hmm the fist aid box may be ok - will have to see if my PC actually fits there though.
    I can just put the first aid kit in the boot.. I have never actually used it - but you never know haha.
  1. E46 CarPC with Original HU
    By samourr in forum General Hardware Discussion
    Last Post: 08-11-2011, 07:40 PM
  2. mk 5 ford fiesta work log *56k warning*
    By Tone in forum Worklogs
    Last Post: 07-28-2007, 01:21 PM
  3. E46 steering wheel controls to carpc...
    By JTfromSTL in forum Input Devices
    Last Post: 08-29-2006, 01:04 PM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
