Thank you!
Beautiful!!
My car installation mp3car thread "showing off project"
Thank you!
I am also making progress! I have received the longer flatflex for the LCD panel buttons. (to the right on the pic)
Next step is to fit the main pcb into the BM and measure up the signals to the motor and from the sensors.
I needed this to be done before I can order the pcb.
nice! so let me ask you...the long flex cable (on the right) will be connected to your pcb?
Correct. And then I will let the pcb simulate a series of button presses at startup to make sure the LCD panel gets into the correct state. Well, that is the plan anyway :-)
sounds awesome! i will post pictures of the "cable retract" system either tonight or tomorrow. Came our pretty neat!
looks great!
what texture and paint did you end up using?
Brian @Nexations Creations
Specialist in Custom Interior Fiberglass OEM Replication Work.
AIM: Exus28
E-Mail: Exus28@aol.com
thanks Brian!
I used what you suggested. SEM Texture and SEM Satin Black. Absolutely amazing products!!!! Thank you
yea, they work great together!, a little difficult when spraying bigger panels though because the texture starts to become non-uniform, and then you have to sand down the texture because it becomes rough, but it looks like you did a great job!
AIM: Exus28
