Results 1 to 5 of 5
Thread: where to place carpc?
    Aug 2007
    i got an honda civic coupé from 94 and i want to install an carpc in it...
    at first i thought i would install it in the trunk, but after i started planning i wonder if i could find a better place...
    the reason why i don't think the trunk is a good place anyway is because of the heavy wiring required:
    4m screen wire
    4m usb wires (for mouse, keyboard, etc.)
    4m audio cable from sound card to headunit and from headunit to amplifier = 2x 4m audio cable
    and maybe more...
    so i wonder if you have a good idea where i can install my carpc?
    Low Bitrate eigenVector's Avatar
    Apr 2009
    Quote Originally Posted by menthos View Post
    4m screen wire
    and maybe more...
    Common places include the glove compartment, and if it's small enough under a seat.
    Personally I have mine in the trunk, but like you said, I've had to run a lot of extra wireing, and also had to overcome some heat issues with it being in the trunk as well.
    Feb 2006
    Melbourne, Australia
    You could also mount it behind the dash if it's small enough.....
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Low Bitrate Dexamenus's Avatar
    Nov 2008
    i'd say behind the dash if you can, glove box if you dont mind loosing the storage space, or under a seat if there is room.
    or if there is enough room in the passenger footwell, make up a false floor to hide it under, will look normal, be safe, and easy to work on
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    I would get over the fact that you need heavy wiring from the trunk. I have mine in my hatchback and ran all my wires from the front to the back in less then half a day. I did this because I didn't want to put it under the seat, in the glove box, or behind the dash taking a chances of over heating. So far it's been about two years and it's running strong!
  1. For Sale: CarPC EZ v.2.5d
    By stevent76 in forum Classified Archive
    Last Post: 12-23-2005, 09:55 PM
  2. CarPC Gets BLACKOUT! when monitor is connected!
    By Sympotonic in forum General Hardware Discussion
    Last Post: 12-08-2005, 04:30 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
