Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: Plastic Sources
  1. #31
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by thekl0wn View Post
    Just so we're clear, I meant that the selection of fittings in PE is vast... However, not at HD/L/M's... We actually don't have a local source for the fuseable joints, and have to order them.
    I'll still check it out. And I'll look around on the Web, too. I appreciate the tip.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at
  2. #32
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Just a quick update on one source of HDPE... I checked into the piping that dad uses, and it's a true virgin HDPE and we have a lot of the scrap that gets discarded daily. If anyone is in need of a high grade HDPE, simply send me a PM and I'll get you however much you need at the cost to ship it. Most of the 2" and below pipe is around 1/8", but the larger diameters we sometime use gets up into a full 1/4 of thickness and more.
    Play with it, 'til it's broke.
  1. Plastic Welder - anyone used?
    By evandude in forum Fabrication
    Last Post: 11-15-2010, 10:55 AM
  2. Played with my new air-powered plastic welder
    By thebigthn in forum Fabrication
    Last Post: 05-18-2009, 07:48 PM
  3. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 11:51 AM
  4. plastic reinforcements (kickpanels/speaker baffles)
    By therussman2002 in forum Fabrication
    Last Post: 06-23-2005, 11:00 PM
  5. Help With Sanding and Painting Interior Plastic
    By xhazn in forum Fabrication
    Last Post: 05-06-2005, 07:18 AM
