Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Protect my computer against a collision? Impact - car crash
  1. #11
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by 528i_tourer View Post
    Maybe i am overoverover worried with this but i like to prevent and dont take it easy on this....
    PC is protected by a 30 A fuse...the green one!!!
    Is this too much...my PSU can go 250 W on consumption....
    Thanks!!
    Yes, you are overworried, yes the fuse is too big. Take a multimeter and check the amp draw on the computer during 100% cpu usage and maximum devices you will used connected. Find a fuse for either exactly or slightly more than that number. That way you're 100% sure that if something flukey is happening, the fuse blows. This is good for not just crashes but other things like faulty devices and whatnot.
    Quote Originally Posted by TheGuv View Post
    30a fuse? My cig lighter runs on that and I don't worry myself about that!
    30 amp fuse for cig lighter? Unless you've changed something the cig lighter circuit is designed for up to 10 amps. I've drawn 40 out of mine with a 40 amp fuse and DID actually have an electrical fire. Theres a reason why the car has the fuses it already has. Obviously, if you've rewired it and done your own thing it should be fine.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  2. #12
    Variable Bitrate csfile's Avatar
    Feb 2009
    Very important. Make sure you select the proper wire gauge to handle the amperage that you are fusing. If the wire burns up before the fuse is broken... For example, 30A fuse on 20 gauge wire is a bad idea.
  3. #13
    Jun 2009
    London, United Kingdom
    Quote Originally Posted by PaulF View Post
    Came out of Ford like it... Got a socket in the dash, one in the glovebox and one in the boot... If what you're suggesting is right then for my car to have a 30a fuse is justified by the 3 sockets.
  4. #14
    Jan 2008
    Dartmouth, MA
    That's weird but nice. On most cars they'll give a 10 amp fuse for all the sockets combined, which is highly annoying because each socket can actually handle 10 amps, but they just don't wire it correctly.
  5. #15
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    just another vote for over worried about nothing so long as you are properly fused... I have tons of equipment in my truck that run at over 60 amps but everything is fused and wiring is larger than necessary. You have far more chance of the battery shorting out with the sheet metal and catching fire than the PC. If you are running 120v such as me with an inverter the moment that it shorted out the Inverter would either go into overload or blow its fuse again nothing to worry about.
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 06:09 AM
  2. Replies: 5
    Last Post: 03-02-2008, 05:23 PM
  3. Car computer vs regular head unit
    By dlewis187 in forum General MP3Car Discussion
    Last Post: 12-11-2005, 12:31 AM
  4. Replies: 19
    Last Post: 10-26-2005, 11:53 PM
