+ Reply to Thread
Results 1 to 10 of 15
Thread: Protect my computer against a collision? Impact - car crash
    Apr 2009
    At home
    Well guys i am searching a material that could satisfy my needs for what i am doing with my carpc now...will build a plexiglass (acrylic one) case to put my motherboard in there.....just put the pc on my car and then i need to have some kind of material that would protect my pc case against a possible car accident!
    I am not worried about my computer!
    I am worried about my car and pc electricity!!
    So to avoid a broken pc touching my car (i mean electrical problems from that crash....) and having any kind of fire, i plan to build a case and put surrounding that case some kind of foam (??) to protect against collision! I guess an impact absorption material that would protect the case/pc from getting smashed....
    Have you got any idead of any kind of material that could satisfy these need?
    Variable Bitrate csfile's Avatar
    Feb 2009
    Where do you plan on putting the PC? If you mount it in an area where it wouldn't get damaged unless you're in a major collision, then you don't have to worry about making some kind of foam.
    If everything is fused properly, wouldn't that prevent the electrical shorts from causing fires?
    Vendor - Qube colin's Avatar
    Dec 2006
    Quote Originally Posted by csfile View Post
    If you get in an accident, chances are your wires will be trashed, your PC will snap in two, and your fuses will protect from fires. Make sure you fuse it right like csfile said and you'll be fine.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    No worries if you fuse it properly. Any electrical short will blow the fuse and cut the power.
    Want to:
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I have 'crash' tested three installs... the PC was fine, much better than I did. Two of those totaled the truck... both with bent frames....
    Worry about yourself, think no more on protecting the PC or the car from the PC. No need.
    TruckinMP3
    Read the FAQ!
    Dec 2008
    i agree.. worrying about a computer at times when your life would be in danger sounds pretty ridiculous. just take some pictures of your install and send them to your insurance company if anything happens...
    May 2009
    Fuses... very SRS business.
    But seriously, If the impact is anywhere close to the PC, it's gonna be trashed no matter how much tempur-pedic you cushion it with. Just fuse everything properly like mentioned before and you won't have any electrical fire issues.
    Apr 2009
    At home
    Ok guys!
    I guess you didnt notice: i dont care about my pc...just care about myself of course....but that also depends on my car too..cause if there is a fire on my car...i may also be injured...
    I have my pc on the rear, near the tailights...this is a wagon so i put in here
    will go in here where is the multi cd player...so i guess in case of a rear colision or lateral one could have some problems or not...i just wanna prevent the pc parts from touching the frame....i guess its my major concern with electricity...so i would like to surround my case with some kind of impact absorption material if its worth the money and the effort of course.
    in fact i also have all protected with fuses like the ones you can see in here:
    Maybe i am overoverover worried with this but i like to prevent and dont take it easy on this....
    PC is protected by a 30 A fuse...the green one!!!
    Is this too much...my PSU can go 250 W on consumption....
    Thanks!!
    Jun 2002
    Colorado
    Nice an tidy on the wiring. I think you will be fine with the fused power.
    In the unlikely event of a wreck that results in a short the fuse should do it's part.
    Additionally, it is not like shorting the battery terminals, various parts of the PC will fail before the risk of shock and fire. This is also true of desk top installs.
    Cheers
    TruckinMP3
    Read the FAQ!
    Jun 2009
    London, United Kingdom
    I think your worries are pretty unfounded.. Your PC is running off of 12volts and pretty low amps... 30a fuse? My cig lighter runs on that and I don't worry myself about that! Plus the majority of materials I can see in your photos wouldn't catch fire in any event other than being soaked in petrol! And your tank is UNDER the car, so that's pretty unlikely too!
    Seriously, nothings gonna happen lol.
+ Reply to Thread
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  2. Replies: 5
    Last Post: 03-02-2008, 06:23 PM
  3. Car computer vs regular head unit
    By dlewis187 in forum General MP3Car Discussion
    Last Post: 12-11-2005, 01:31 AM
  4. Replies: 19
    Last Post: 10-27-2005, 12:53 AM
