Originally Posted by
tempgp
oh sorry im just 7 y/o so your comenta is N/A, but if you relly prefer so I can post it in Russian
As to 100mph efficiency. Thats all depands on your angle of the wing. If you dont plan to travel more then 80 you can safly put say 14-18 degrees (but if you hit 100+ speeds you will feal that back of the car is pressed down to the ground) and if you go to say 135 (or more if you dont have governor) then you may brake strings or lover the car to the level of the ground and get lots of spartks =)
In another words speed + angle = derectly propostional to efficiency. Min speed though is 60mph. You can try yourself, get 40+ mph and put your nahs outside the window, make sure your fingers are close togather then play with different angle position, then go to ~60-80 mph and see the difference. (Airctaft take off speed is 60-80mpg. 60 for small propeler one, 80 for jets... or hmm well thats in should be in km/h, russian Mig29 takes of at 80Km/h with flaps extended)
